585,992 active members*
5,276 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas st-30 recovery after battery lost
    Oct 2016
    8
    Dear forum members
    Regarding Hass ST30
    I had memory lost after my battery died , so i took the Hass recovery USB and restored my machine and everything was restored except my C axis - showing me "C axis drive alarm" .
    I double checked my parameters with original machine parameters and its they are the same , tried to replace C axis drive and still kept showing the alarm.
    Before the battery died C axis was fully operational.
    Did anyone had this problem before?
    Much appreaciation!
    May 2016
    526
    Re: Haas st-30 recovery after battery lost
    Silly question is it turned on in your parameters?
    Oct 2016
    8
    Quote Originally Posted by mbservice View Post
    First of all thanks for replying !
    Well i did install all parameters via "Hass USB" ( the original that I recieved with the machine) and verify also on the machine that all parameters are as they should be .
    Is it possible that it is special option that only hass person can open ?
    May 2016
    526
    I think it's an option parameter on your machine
    If you check the paperwork that came with your machine there should be a page showing options that can be enabled and the relevant codes to turn them on
    Apr 2019
    help for parameters
    regards. friend I have the same problem of the loss of parameters after the battery discharge. You can give me the parameters of the machine. send them to the email [email protected]
    I appreciate your help.
    Thank you
  1. Replies: 1
    Last Post: 04-10-2019, 09:12 AM
  2. Recovery of lost program
    By BCCStudent in forum Education - Teachers and Students Hangout
    Last Post: 10-30-2018, 04:17 AM
  3. Lost battery and parameters TM-1p
    By paradiddle1 in forum Haas Mills
    Last Post: 06-21-2016, 02:10 AM
  4. Recovery of lost licence: BobCAM can not help V2 owners
    By 3D-companions in forum Tutorials
    Last Post: 05-18-2016, 10:16 PM
  5. FH6800
    By jimica in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2013, 10:49 AM
