586,009 active members*
4,900 visitors online*
Thread: Slow Jog
Results 1 to 7 of 7
    May 2003
    132
    Slow Jog
    How can I get my sloy jog to increase and want does max excel do. my help files are corrupt. I'm using gecko drives and they run great at high speed but not at slow jog.
    6855
    If I remember you can change the jog value in the set-up menu.
    May 2003
    132
    I can't find a place to change my slow jog.
    Mar 2004
    120
    Don
    From the main screen press ALT-S to get to the setup screen... then down arrow three times to "unit, label, jog and F/R settings"... press enter to open this screen.
    Now arrow down to Slow jog settings and press enter to edit the required axis.
    esc back to main setup menu and down arrow to save settings... enter to accept and esc once more back to the main screen.
    HTH
    regards Gary
    embrace enthusiasm to accomplish the task
    Gary Davies... www.durhamrobotics.com
    May 2003
    132
    Thanks, I have things running pretty well now. I really like cncpro. The only thing I wish it had was a way to get a file in a diffrent directory other than in cncpro\gcode or maybe a:\. I have to get out of cncpro to load a new file.
    Thanks the help
    Don C.
    Mar 2004
    120
    You ask and it shall be delivered...
    Alt-F for the file menu, arrow down to "Create or Edit G Code File"
    Now in the editor... Alt F for the File pull down menu, down arrow to open... you now have a DOS file/directory screen
    Use the tab key to switch between windows and now you can load files from anyware on your system.
    Alt-f to save the file to cncpro\gcode from the editor.
    NOTE: to be able to load the gcode file into CNCPro it must have been saved with a .txt extension and direct disk access must be enabled in the cncpro.exe properties
    regards Gary
    May 2003
    132
    Thanks I'll try that. That was my only complant with cncpro. I have to load files from my design software (signlab) and its a pain the othe way.
    Thanks again for all you help.
    Don C.
  1. TurboCNC and KCam3 a lost cause?
    By Davedbq in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-27-2005, 09:03 AM
  2. Replies: 7
    Last Post: 01-02-2005, 09:41 PM
  3. motors won't slow jog
    By gv71 in forum Gecko Drives
    Last Post: 11-05-2004, 02:05 AM
  4. It's me again..........with this jog file.....
    By Darc in forum CamSoft Products
    Last Post: 10-26-2004, 09:47 PM
  5. Softlimits and Jog
    By HuFlungDung in forum CamSoft Products
    Last Post: 03-08-2004, 11:28 PM
