585,982 active members*
4,549 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc/Robodrill rapid feed parameters
Results 1 to 13 of 13
    Sep 2010
    135
    Hello all,
    I have a Robodrill a-D21LiA5 with Fanuc series 31i-model B5...
    This machine is crazy fast and gets dangerous to run specially when we do a lot of one offs.
    What parameters can I change to reduce the rapid feeds to lets say in half.
    and how to change those parameters ?
    cheers
    Feb 2011
    353
    Re: Fanuc/Robodrill rapid feed parameters
    there should be 4 buttons that say low, 25%,50% and 100% these will control the rapid
    Sep 2010
    135
    Quote Originally Posted by rcs60 View Post
    Yes, there is low, 25%,50% and 100% but the low is way to slow and the 25% is way to fast for 25%---this machine is crazy fast and I'm already seeing people crashing it big time. Have you seen a robodril running? it may sound ironic---Sometimes seems that the machine wants to run away through the shop. I can post a video if you like? A good example, I never seen a machine changing tools so fast, I'm looking at the tool change operation and the tool is already on the part. Is faster than my eyes. sound funny but is the true!!!!
    If I could increase the low a little and decrease all the other ones by 50% would be optimal for the type of work we do.
    Parameter 1420, Must be in MDI or ESTOP and turn on PWE which can be found under the offset/setting screen under settings. Parameter Write Enable
    Sep 2010
    135
    Quote Originally Posted by drdos View Post
    Thanks drdos, works like a charm now...
    I was just wondering if there is a separated parameter for the "low" I basically wanted to increase the low feed...
    cheers
    P_FX
    Jan 2014
    106
    Quote Originally Posted by PRINT_FX View Post
    cheers
    P_FX
    I have never worked on a robodrill but I would answer no, you cannot modify the low speed. The parameter modify overall speeds. The percentages and ranges are done in the machine logic.
    Sep 2010
    135
    Quote Originally Posted by bill4807 View Post
    Sound odd, thanks bill4807, now I know.
    Sep 2010
    135
    You are right bill4807. there is no parameter for the "low"
    Jan 2014
    106
    Well that took a while to troubleshoot. Lol.
    If i may ask how did you find out?
    Sep 2010
    135
    too funny!!!
    I decided to look up the boring book and couldn't find any parameter info for the low---its a default setting. which is dumb!!! always thought Japaneses were a little smarter LOL
    Dec 2009
    953
    ,,,,,,"have you seen a robodril running? it may sound ironic---Sometimes seems that the machine wants to run away through the shop. I can post a video if you like? A good example, I never seen a machine changing tools so fast, I'm looking at the tool change operation and the tool is already on the part. Is faster than my eyes. sound funny but is the true!!!! """"
    it seems that japaneses did a machine that you can not handle...LOL....dunno who is smarter and who is not.
    Sep 2010
    135
    Quote Originally Posted by zavateandu View Post
    I can handle it indeed---is just, doesn't make sense the low rapid feed VS the 25%/50%/100% which only have one parameter, that is all.
    If this machine is designed for a production environment---why not a fully optimization? Maybe you can answer me?
    Jan 2014
    106
    It just depends on the builder. Ive seen a bunch of machines come from korea with the FEED variable from 0-120% at 10% increments and then have the RAPID at 0-25-50-100%. But other machines from japan having the FEED and RAPID on the same 0-120% with 10% increments. Depend on the programmer i have found since some like the controls independant.
    I cannot comment on why, i am not a part programmer.
    To answer in my own way about adjusting it further is that mostly i will not program something so intricate unless it is a requirement or custom added feature.
  1. New Fanuc Robodrill or 7000 hour robodrill with all the bells and 4th axis?
    By The_R1_Kid in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2018, 01:26 PM
  2. Doosan VMC fanuc - no rapid or feed when spindle off
    By Zbuilder in forum Daewoo/Doosan
    Last Post: 04-04-2018, 02:51 PM
  3. Fanuc OT Feed & Rapid Problems
    By TR MFG in forum Fanuc
    Last Post: 01-22-2007, 09:19 PM
