I don't think you'll see a lot of difference between 12" and 15" or even 18". Once you get over 12", you're basically trying to keep the legs from flexing.Still, l left with an open question. While bigger is better, how big is big enough? At what size do I reach the point of diminishing returns?
How good id good enough is one of those questions only you can answer.
I believe the value of the resistor is just telling the onboard processor what to limit the current to. It's not used or functioning like a normal resistor would be.I don't understand why decreasing the size of the resistor would correspond to reducing the output current.
