585,991 active members*
5,080 visitors online*
    Oct 2018
    Question HELP Transfer Heidenhain 410PA
    Hello!
    Machine: Bridgeport 600/22 Digital milling machine
    Controls: Heidenhain 410PA PLC: 12D01V12 NC: 286060 15
    Please help. I am trying to send programs from a computer to a machine.
    The machine has an RS 232 interface. No Ethernet / Lan.
    - I connect the cable to the machine and computer (RS232- USB2.0)
    - I'm running TNCremo
    - I set the folder, 410PA control, Protocol Send / Receive (FE), Serial port: COM5, Baud rate 9600. I have the same settings on the machine. (FE, 9600).
    - status at tnc server Ready
    - I enter the Edit> PGM MGT> EXIT on the machine
    - I press Transfer EXIT> TNC
    - I enter the name of the program to control identically as in the computer, eg: wymiar (extension .h is already in the window)
    - confirm ENTER
    And here is the problem. The file is not transmitted. Machine control stands. TNCserver status - Ready.
    What button on the control will press the Key non-functional message.
    Only when I disconnect the cable, the machine runs normally and the message Entry value incorrect is displayed.
    I got under control by avoiding the port at the front of the machine. - the same situation as the above control does not help.
    I've crossed two cables. - did not a
    I exchanged a small plate next to the port in the machine. - did not help
    This set works on another machine without the slightest problem. (Bridgeport 600/22 HH 410)
    Please help
    Sep 2007
    7
    Re: HELP Transfer Heidenhain 410PA
    HI. DO YOU SOLVE THIS . I HAVE THE SAME.
    THANKES IN ADVANCE FOR YOUR HELP.
  1. Heidenhain TNC 355 transfer from PC problem.
    By lazovicdj in forum HEIDENHAIN -> TNC
    Last Post: 07-21-2018, 06:08 AM
  2. Heidenhain TNC 355 transfer from PC problem.
    By lazovicdj in forum SERVICE FOR CNC-MACHINES
    Last Post: 07-18-2018, 08:42 AM
  3. Heidenhain TNC 355 transfer from PC problem.
    By lazovicdj in forum Questions or Problems
    Last Post: 07-18-2018, 08:37 AM
  4. Heidenhain TNC 410PA movement monitoring error in X and Y
    By wojtekthx in forum Uncategorised MetalWorking Machines
    Last Post: 03-23-2018, 02:26 PM
  5. Heidenhain TNC 145 C control - Data Transfer
    By rfarleman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2011, 07:36 PM
