584,862 active members*
5,708 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Heat treating D2 with helicoil inserts?
    Oct 2017
    11
    We have a D2 part that needs to be heat treated to 60 Rockwell that has two m6 helicoil inserts in it, will they be alright if we heat treat it with them in there? Standard practice for d2 heat treating is to doubble temper correct?
    Sent from my SM-G950U using Tapatalk
    Aug 2009
    1567
    Re: Heat treating D2 with helicoil inserts?
    case RC60...how deep...005/in to .015...use 8620
    Aug 2015
    36
    Hello Johnsmitty,
    I would send the part to heat treatment without the helicoil inserts and add them after the temper. But I haven´t had a piece in such situation, this would be my approach.
    Please let us known what was your call and the output.
    Greetings
    Quote Originally Posted by JOHNSMITTY View Post
    15362
    You need to take them out before heat treatment, if you don't and they are a good at what they do, then they will take them out
    Double temper sometimes more than a double temper can be used, depending on how refined you want the core
    Mactec54
    15362
    Quote Originally Posted by machinehop5 View Post
    He is using D2 tool steel
    Mactec54
  1. bend from heat treating
    By brian257 in forum MetalWork Discussion
    Last Post: 07-19-2016, 09:29 PM
  2. THE BEST WAY TO EXTRACT HELICOIL INSERTS?
    By david rendon in forum MetalWork Discussion
    Last Post: 03-25-2011, 07:31 PM
  3. re-heat treating 6061 T-6?
    By parkerbender in forum MetalWork Discussion
    Last Post: 03-22-2010, 02:55 PM
  4. heat treating 416
    By TANKER in forum Uncategorised MetalWorking Machines
    Last Post: 02-18-2009, 09:32 PM
  5. heat treating
    By gosserwb in forum Moldmaking
    Last Post: 06-26-2007, 09:21 AM
