Hello, I have a Toolmex lathe we just had to replace 8050 CPU on. We uploaded new parameters to the 8050.
The spindle runs but does not run at correct rpm. 1st gear the machine will only run at 80 RPM Regardless of setting.
2nd gear will only run at 300. and 3rd will only run at 800.
Machine does prompt gear changes as it should
The RPM on the left on the screen seems to be correct, but no matter what I put in I'm stuck on those RPMS.
I have double checked spindle parameters as well as the PLC program and I can't seem to find any answers.
Any help would be greatly appreciated. Thanks!!
