I need to create two slots in a part. One is not straight, it has a jog in it. The endmill is the same size as the slot.
I can't figure out which toolpath to use, and how to handle the entry and step downs.
I have created some wireframe geometry to make it easier to select the contours, but I'm still struggling. Slot tool path won't work, it can't handle the bend...
Any guidance would be much appreciated. I have attached a mcam copy of the part.
Also, I have to finish bore the 4 counterbores using a single point tool and a boring head. Is there a cycle to do that? I need to finish the bottoms of the holes as well with the same tool.
Thank you,
Bryan
Name:	oil pump body.jpg
