585,992 active members*
5,978 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko 201 Mounting Screws
    Apr 2006
    4
    How do you access (install) the Gecko 201 mounting screws located under the terminal block?
    It does not seem possible to get a tool in there with the limited clearance.
    Any advice would be appreciated.
    Thanks.
    Nov 2005
    222
    Re: Gecko 201 Mounting Screws
    The terminal blocks are on pins and can be lifted off. Just grab the edge of the block and lift straight up.
    John
    Apr 2006
    4
    I looked at the underside and saw solder joints. Assumed it was one piece.
    Thanks for the info. Very helpful indeed.
  1. Nook Acme screws 1/2-5 10tpi mounting parts
    By JackMath in forum Linear and Rotary Motion
    Last Post: 10-08-2018, 10:19 AM
  2. ACME Lead screws and Mounting Hardware
    By royalcrown in forum For Sale Only
    Last Post: 05-08-2015, 01:51 AM
  3. Replies: 4
    Last Post: 10-21-2013, 08:32 PM
  4. PSU mounting screws
    By alnicov in forum Xylotex
    Last Post: 08-27-2006, 01:18 PM
  5. mounting mill sideways for cleaner screws and chips
    By lesd in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2004, 03:07 PM
