Would this be acceptable? Its not the same shape but it looks good to me
Yes that worked much better thank you. Was able to connect two lines so I was able to make 4 chains.
Took me a bit to get the rest. I made a solid but when I removed the middle it deleted my walls on the inside as well. So I used planar for the top and bottom and I was able to keep the internal walls. Now just to figure out how to give the tune wall to top of the flat flange a radius and I can get started.
Exactly whatever works. First time I was able to get this function to work but worked much better.
Something odd happens with the tool path I’ve never seen. I send the mill down the center of the oval and it stops about half way. I figured once it got to the part of the drawing that was negative it was stopping on its own and I needed to write for the other side. But when I rough in the Z it seems to be running do to my surface, but then it cuts another .250 on another pass for some reason. I’ve tried everything I can think of. Makes no sense.
