585,996 active members*
4,083 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Vision 2550 routing table with series 3 contoller, need z axis microstepping settings
    Hi
    I need the microstepping jumper settings for the zaxis stepper motor controller. While working on it, I think one of my students change the switch settings, it was all 4 switches on the off position, which results in the motor not working. When I change it to match the same jumper settings as the x and y axis (sw1=on, sw2=on, sw3=off, sw4=on), the z motor works, but when I check the accuracy of the movement with a tape measurement, I am off by amost 50%. After experimenting with different switch settings, I get the best results with sw1=off, sw2=off, sw3=on and sw4=on. Based on the IM2000s datasheets, I believe (if switch on means 0) the x and y axis is set to 32 microsteps and z axis is 16 microsteps. Can any one please verify if this is the correct settings. Thank you
    Nov 2008
    5
    Re: Vision 2550 routing table with series 3 contoller, need z axis microstepping sett
    Hello,
    The correct resolution settings for the Vision series 3 controller are below:
    X: 3 off
    Y: 3 off
    Z: 1,2 off
    Joe
    Thank you so much
    Nov 2008
    5
    Your welcome.
  1. Gravograph IS8000 or Vision 2550
    By aztaiko in forum Engraving Machines
    Last Post: 07-21-2011, 08:15 PM
  2. Replies: 0
    Last Post: 11-26-2009, 12:56 AM
  3. Replies: 0
    Last Post: 10-23-2009, 01:01 AM
  4. NEW VISION CNC ROUTING SYSTEMS WEBSITE
    By CNC602 in forum News Announcements
    Last Post: 10-01-2009, 06:35 PM
