585,902 active members*
4,219 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Newbie Gravograph conversion help
Results 1 to 14 of 14
    Nov 2017
    6
    Gravograph Is400 TM conversion... we sold our Gravograph on Ebay, but UPS damaged and they buyer refused. We got it back and the brain (separate box control) is fried. We have an extra cohesion 3d and Arduino board but are novists at best when converting. We already have two lasers and just want to use for metal engraving machine and cutting. Any advice?
    Sent from my SM-N960U using Tapatalk
    Mar 2016
    22
    Re: Newbie Gravograph conversion help
    Try MASSO, Hind Technology.
    Regards,
    Arie.
    Sent from my iPad using Tapatalk
    Sep 2005
    1740
    Unless you have experience in designing and building CNC machines and setting up, I would sell the machine for scrap and purchase one that you know works.
    Or Gary Campbell does CNC conversions, a google search might bring him up or you will find him over on the Acorn Forum.
    https://www.camheads.org/showthread.php?t=3625
    15362
    Quote Originally Posted by angelalyn1975 View Post
    What is fried in the control, it can't get fried in shipping damaged yes
    Should be quite easy to convert if the stepper drives are in one piece, you can use Mach3 to get you going, so you only need Mach3 and a Breakout Board, and may be some stepper drives, what model Gravograph do you have
    Mactec54
    Nov 2017
    6
    It is a Gravograph Is400 TM
    15362
    Here is someone that may be able to repair what you have, this is a PDF but the information is in there, are the 3 axes or mechanical parts undamaged
    https://engraverschoice.com/uploads/...flyer_2014.pdf
    Mactec54
    Sep 2005
    1740
    Anything Gravograph is going to cost you an arm and a leg. Gary Campbell is an expert at conversions and is just not some no name guy on the internet he is very well known all over in the CNC world and will do it right the first time.
    Nov 2017
    6
    The control box is just not communicating and shorting out.
    Nov 2017
    6
    Would it be less expensive just to do a breakout board and convert? I hate their software anyway lol.
    15362
    More than likely, if your stepper drives are ok then yes a Breakout Board is all you would need and Mach3 would get you going so $10 and some time
    Down load Mach3 and have a play with it, this will run up to 500 lines of code without any cost, to see if you like it there is plenty of help with Mach3 if you need it
    Mactec54
    Nov 2017
    6
    Thank you so much for the advice and help. We are going to move forward with the conversion.
    Nov 2017
    6
    Any suggestions on a breakout board for the gravograph Is400?
    15362
    You will need to post Photos of what is already there then we may be able to see what needs to be remove and replace would be the first place to start
    Mactec54
    Sep 2005
    171
    I have done several gravograph conversions, what do you have for a budget, do you have a control software in mind?
  1. I am a newbie need help on cnc conversion.
    By Jparker1983 in forum Benchtop Machines
    Last Post: 02-11-2017, 04:04 AM
  2. Newbie: vertical column Cnc conversion
    By jivetin in forum Mini Lathe
    Last Post: 06-27-2011, 06:56 PM
  3. Newbie Advice on VFD conversion
    By ZigFire in forum Australia, New Zealand Club House
    Last Post: 05-17-2011, 03:01 AM
  4. Newbie Help Please with Motor Conversion
    By Dezmond in forum Bridgeport / Hardinge Mills
    Last Post: 01-05-2011, 04:36 PM
  5. Newbie - Proxxon BFW 40 CNC conversion
    By Trevix in forum Benchtop Machines
    Last Post: 11-19-2009, 03:27 PM
