585,997 active members*
5,152 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > GRBL 1.1 ARDUINO uno pinouts
    Mar 2011
    357
    with regards to limit switch pinouts I have seen some places noting pin 9,10 and 11 for X,Y and Z limit switches
    https://blog.protoneer.co.nz/grbl-ar...or-pin-layout/
    and some articles stating pins 9,10 and 12.
    https://github.com/gnea/grbl/wiki/Se...e-Homing-Cycle
    What is right???
    1943
    Re: GRBL 1.1 ARDUINO uno pinouts
    Depends which version of Grbl you are using. Pin 11 is used for PWM, so the Z axis swapped from pin 11 to pin 12 when PWM support was added.
    Mar 2015
    409
    On the arduino uno R3 and GRBL version 1.1f the pins are 9,10 and 12 as stated in the GRBL Wiki.
    If you use a different GRBL version, you have to follow the documentation for that version.
    If I remember correct, the 9,10,11 pinout was for an older GRBL version. The protoneer link is dated 2013/01/30!
    Mar 2011
    357
    yes I am using 1.1 so I will use 9,10 and 12.
  1. GRBL interfacing with other arduino? Maybe? No?
    By james_III in forum Arduino
    Last Post: 08-01-2018, 10:53 PM
  2. Arduino GRBL VS LinuxCNC
    By valmar in forum DIY CNC Router Table Machines
    Last Post: 01-15-2018, 05:50 PM
  3. Arduino/Uno/Grbl
    By Mckyjns in forum Arduino
    Last Post: 08-22-2017, 03:14 AM
  4. Arduino Mega grbl
    By cilim in forum Arduino
    Last Post: 08-10-2016, 02:12 PM
  5. arduino nano with grbl
    By mrsnowie in forum Hobby Discussion
    Last Post: 01-06-2016, 06:25 AM
