585,743 active members*
4,991 visitors online*
    Sep 2009
    277
    DIY Build - CO2 laser
    Hey guys
    Are there any good sources for laser builds and the wiring plans etc? It's not rocket science buy I want to see how water flow protection is incorporated as an example
    Sent from my SM-N960F using Tapatalk
    Nov 2008
    644
    Re: DIY Build - CO2 laser
    Normally there is a switch on the water that drives some terminal to ground or high on the power supply. Like a safety switch on the door. If during the cut the water stops then the beam stops. On my machine the controller would keep going. Chillers have this output. Just pull up a the terminal diagram on a laser power supply.
    Sep 2009
    277
    Quote Originally Posted by Dean448 View Post
    AHHH ok that makes good sense. Thanks
  1. would like to build a laser
    By EIdesignstudio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-16-2015, 04:03 AM
  2. DIY Cco2 laser build
    By vikkedlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-23-2015, 09:57 AM
  3. Buildlog 2.x laser build
    By mondo50m in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-11-2012, 04:06 PM
  4. CO2 LASER / Build It
    By Chivo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-01-2012, 12:31 AM
  5. build the CNC laser
    By C-TECH in forum News Announcements
    Last Post: 06-01-2010, 12:07 PM
