585,902 active members*
5,091 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Issues with Slave axis while running in CNC mode Kstep
    Apr 2015
    8
    Hi All,
    I'm building a setup which requires 2 stepper motors turning the same shaft in order to move a joint in a robotic arm. They are on opposite ends of the shaft so they need to turn opposite of each other. I got the setup working using kmotion using channel 0 and 1. Both had the same parameters but channel 1 was slaved to channel 0 and gain was set to -1.
    This worked well when I tested it with step response but didn't work when I tried to get it working with Kmotion. I used the same file I tested everything with as the init file and started it up. Channel 0 mapped to the x axis and channel 1 mapped to the y axis instead of channel 1 being a slave to channel 0. When I tried to move the joint one motor moved and the other stayed still.
    Is there a way to use one axis as a slave to another in a CNC application or is there another way to solve this problem?
    May 2006
    4045
    Re: Issues with Slave axis while running in CNC mode Kstep
    Hi henradrie,
    With such a configuration you only have a single GCode Axis X from KMotionCNC's point of view. So only configure the X axis to the Master Axis with:
    DefineCoordSystem(0,-1,-1,-1);
    TK
    http://dynomotion.com
  1. Y Axis + Slave not running together when running G-Code
    By Fierra in forum Mach Software (ArtSoft software)
    Last Post: 05-19-2017, 08:56 AM
  2. How i got my SX3 mill up and running with Kflop and Kstep.
    By jossa in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-13-2015, 01:36 AM
  3. Mach3 + KFlop/KStep weird Y axis emergency mode problem.
    By Benc1985 in forum Mach Software (ArtSoft software)
    Last Post: 08-12-2014, 11:45 PM
  4. Mach 3 slave axis issues
    By squigly in forum Mach Software (ArtSoft software)
    Last Post: 02-03-2014, 08:17 PM
  5. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
