585,557 active members*
3,484 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Takisawa TS-20 With Fanuc 6T version A Spindle problem..
Results 1 to 11 of 11
    Jan 2010
    7
    Problem: Spindle not running at all, not running in jog, not running in MDI..
    When i power up machine There is no alarm, I can return to zero with X and Z axis. In the moment i give command for spindle to turn i get Not Ready alarm on Screen without any number. I cannot reset on Fanuc reset button, it is strange but only resets when i open and close clamps.
    I find clamp inputs and they change in diagnostic screen, and check gear position speed inputs is OK too. On the DC spindle board seems not have any alarm, only one green led is lighting and i think it is in ready state..
    Not Ready should meaning problem or not met condition from Machine side..
    For this machine i only have Ladder and parameter list. Parameter is like it should, nothing changed there.
    What i think it will help me to start running again:
    1. Connection electrical diagram so i can find all inputs and see if the conditions are OK,
    2. All diagnostic inputs, outputs, Parameter meaning of TS-20 .. so i can connect with mu ladder diagram an try to understand the logic for the alarm
    3. Takisawa user manual will help too..
    4. Any suggestion what to try to fix the problem is much appreciate..
    5. Some way to start the spindle without any of the conditions will be good test ..
    Sorry for my bed English
    Thank you for any help
    Re: Takisawa TS-20 With Fanuc 6T version A Spindle problem..
    Try filling the way oil reservoir.
    Sent from my SM-G950U using Tapatalk
    Jan 2010
    7
    Thank you, i checked the oil and it is full with oil, i think there is no problem there.
    Thank you for suggestion..
    May 2016
    526
    Is it fitted with a barfeed
    Jan 2010
    7
    No, it is without barfeed, Thanks
    May 2016
    526
    Does the machine start in manual
    Jan 2010
    7
    Everything is working in manual, jogging homing.. only spindle rotation is not working ether in manual or automatic or MDI. When i give command show me Not Ready..
    May 2016
    526
    Have you checked there is correct voltage going to drive as it sounds like it may be ready but drive not responding
    Aug 2009
    1570
    my two cents...is there Chuck Setting for ID clamping or OD clamping?
    Jan 2010
    7
    Voltage to drive is OK, I order new driver front board and i will receive next week and try if there is problem..I will post here results..
    Yes there is switch for Chuck for ID clamping or OD clamping i try both way with no luck to start spindle..
    Jan 2010
    7
    Someone to send me or sell me electrical diagram of Takisawa TS 20 will be great help
  1. Replies: 1
    Last Post: 10-02-2016, 10:34 AM
  2. Replies: 0
    Last Post: 08-13-2016, 02:30 PM
  3. Takisawa TS-15, Spindle Drive Problem, Fuji DSR Compact, FSD-15DN23, 220V 82A Output
    By mflux_gamblej in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2016, 01:15 AM
  4. Replies: 5
    Last Post: 06-26-2014, 12:02 PM
  5. Replies: 3
    Last Post: 04-07-2012, 08:55 PM
