585,764 active members*
4,475 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Add tool setting probe to Milltronics Centurion 7 knee mill???
Results 1 to 6 of 6
    Apr 2008
    10
    We recently purchased a 2006 Milltronics VKM3 CNC knee mill with the Centurion 7 SLS control. We also have a Renishaw TS27R wired tool setting probe that was a spare for our Haas VMC. We'd like to use this on the Milltronics.
    From what I understand, the control can be setup to used a tool setting probe (and a part inspection / digitizing probe). Does anyone here have experience in this area and can share some insight?
    Jim
    Apr 2008
    10
    Re: Add tool setting probe to Milltronics Centurion 7 knee mill???
    How do I get the PROBE1 and PROBE2 commands to work in parametric programming?
    Playing around with parametric programming, I can setup and use a spare input pin or the pin that is supposed to be used by the probe (axis 1, pin 11 on my machine) to stop / start axis movement. I can do this with WHILE/WEND statements using the IPIN[11] command, but I would prefer to use the built-in commands PROBE1 and PROBE2.
    The problem is PROBE1 or PROBE2 commands don't seem to work. I have set / verified the byte parameters associated with the probe input (probe axis 213 and probe input 214) and verified the status of input pin 1010, but when I try to use it in a program, it halts with a "000 unassigned error".
    If anyone here can shed some insight, it would be appreciated.
    Jun 2010
    132
    I believe you have to purchase the probing option from milltronics, have you contacted them?
    Mar 2019
    Prtty sure you have to have the full blown cnc software for the probe macros to work, looks like you're still on sls. When you say probe 1 probe 2 commands do you mean M Codes? Did you turn the spare mcodes on under the power parameter or set up the macros?
    Oct 2017
    39
    According to the Centurion manual, P899 is to enable digitizing/probe. No idea what number it needs to be set to since 1 and 0 aren’t the regular on/off for that parameter. But if you figure it out you should be able to use PROBE1 and PROBE2, assuming it functions on the SLS control.
    Oct 2017
    39
    Well I was wrong about P899 enabling the PROBE1 and PROBE2 commands.
    P899 enables the PROBE and PROBE XY pages (Menu-F10Util) used with Digiscan 2.
    Trying the PROBE1 command gives me a error 518, Illegal program statement, Command in program statement is not considered valid. Bummer.
  1. Replies: 2
    Last Post: 01-03-2017, 11:40 AM
  2. Old Milltronics Partner 3 knee mill
    By borne2fly in forum Milltronics
    Last Post: 08-02-2013, 09:06 PM
  3. Milltronics VK-3 cnc knee mill
    Last Post: 08-24-2010, 09:39 PM
  4. Need post for Milltronics / Centurion 7 mill
    By hoganj in forum CamWorks
    Last Post: 03-25-2010, 10:05 PM
  5. Tool setting probe
    By JFettig in forum Mach Software (ArtSoft software)
    Last Post: 03-12-2005, 02:33 PM
