586,000 active members*
4,926 visitors online*
    Jan 2017
    52
    Lightbulb Axis Zeroing ?
    Guys,
    I built from scratch a CNC 3 axis Router. I am trying To cut a project and am having issues on exactly where
    to zero the X and Y axis so the tool will start in the proper play the code tells it to.
    When You load the code and look at the little visual window you see the cross hairs of the X and Y axis on the piece.
    Is this where you move your machine to this location to start. ? And then you zero the axis' in Mach3 ?
    On the Z I just bring it down to the surface and use a piece of paper to zero it .
    Thanks for your input,,
    Cubs
    Apr 2004
    5737
    Re: Axis Zeroing ?
    When you make your original part model, the X/Y zero points are wherever they are set in your CAD program. It can be put anywhere, but some usual places to locatet them are in the bottom left corner, or in the middle of the part. The Z axis zero point can be set at the top of the part, at the bottom, or in the center. When you run the model through your CAM program, you have the option to leave the zero points where they were in the CAD system, or to set them someplace else. It's usually a good idea to make a note of where they're supposed to be set, and to leave that at the top of your program (in parentheses so it isn't read by Mach3) for future reference.
    . If your tool is well above the surface and you've set your zeroes correctly, you don't usually have to move to the origin location before starting the program, although it doesn't hurt, and will save the stock from having a diagonal line cut in it if the first move is to a location under the surface of the stock. But before starting the program, you should make sure the zero points are set in the places called for in the CAM program. If the X/Y axes are centered in the middle in the CAM program but you set them in the corner of your stock, then the program will only cut one quadrant of your part from the stock, and the rest will be cut in air - if there's enough room. If not, it will hit the outer limits of your machine and fault out.
    Andrew Werby
    Website
    Jan 2017
    52
    Re: Axis Zeroing ?
    Thank You very much,, I am trying to learn how to do this,,
    This helps me a lot,,
    cubs
  1. Zeroing axis on Mach 3?
    By jimmy5 in forum Mach Software (ArtSoft software)
    Last Post: 08-27-2012, 06:29 AM
  2. Properly zeroing axis on 4th axis setups
    By bebob1 in forum CNC Tooling
    Last Post: 04-16-2012, 02:27 PM
  3. V2XT Zeroing Z-Axis
    By slowbob in forum Bridgeport / Hardinge Mills
    Last Post: 01-27-2011, 07:32 PM
  4. Zeroing A Axis
    By findor in forum G-Code Programing
    Last Post: 10-30-2009, 11:59 AM
  5. Trouble Zeroing A axis
    By MBG in forum Haas Lathes
    Last Post: 03-16-2009, 12:04 AM
