586,024 active members*
4,391 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Open Source CNC Machine Designs > Trying to get my controller to run smoother correctly
    Jul 2017
    57
    Hello Everyone,
    I'm new to this forum. I was on G+, but thrown out after they closed shop. I built my CNC about a year ago and I'm still trying to get the bugs worked out. My machine is a 3-axis (currently) machine with 4 stepper motors, made of 80/20 aluminum extrusion (profile 3030) and driven with ball screws on linear rails. I use an ESS motion controller connected to a PMDX-126 BOB with 4 DM542T stepper drivers and run Mach 4 controller software. Electronics are similar to those of CNC router parts (except for the drivers). I've been having issues with the movements shuddering and staggering during some movements which result in poor cutting. Here's a picture of my machine the results I got while trying to run the V-carve trial cut "Bullshead". I thought, initially, it could either be settings in Mach (i.e. look ahead lines, and exact stop vs Constant velocity mode) but I changed those settings and I still have the same result. If anyone here has some ideas, I'd love the assistance.
    Aug 2018
    621
    Re: Trying to get my controller to run smoother correctly
    Have you checked the machine for any mechanical problems like binding or undersized stepper motors? Also you should post a video of the machine cutting it would be easier for someone to see if it's something obvious. Also post what your tool path is, cutter size, feed rate, spindle speed and so on. It's really hard to say by looking at a couple pictures with not much other information to work with.
    Dan
    1225
    One thing I learned about V-carving lettering is that you need to use a tool intended for engraving and which has a sharp point.An early attempt with a 45 degree tool had areas that resembled the most severely wrong image that was posted and it was because I touched off with the 2mm wide flat tip of the tool.I have since bought one or two engraving tools and that problem went away.
    Before blaming excessive cutting depth and consequent machine flexing,can you give more information as indicated above and please include the software used to generate the toolpath.It may be that somebody can advise of a setting that needs adjusting. It could be something as fundamental as using a value for the angle of the tool tip that doesn't correspond to the actual shape.
  1. 440 not moving correctly after controller swap
    By cowanrg in forum Tormach Personal CNC Mill
    Last Post: 09-04-2016, 09:35 PM
  2. How to Reduce Striations and Achieve a Smoother Cut?
    By lindari in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-27-2015, 05:41 PM
  3. smoother surfaces
    By alanstclair in forum Rhino 3D
    Last Post: 01-27-2013, 12:34 PM
  4. Replies: 8
    Last Post: 11-13-2012, 06:58 PM
  5. What runs smoother steppers or servo?
    By Apples in forum Gecko Drives
    Last Post: 03-17-2008, 08:59 PM
