many of the users use CutLeader for router machine, so a lean entry is prefered to avoid the hurting of tool, and getting a good quality of edge.
The postprofessor of router machine is enhanced further to support the spiral milling now. The control should allow 3 axis simultaneous movement.
This feature is useful specially for small holes. Below is the simulation of the NC code with spiral movement.
Attachment 419146
user just need check on the entry with lean and set the entry angle, the postprocessor would calculate and generate NC then.
