Quote Originally Posted by bustamam View Post
Hi machinehop5,
I manage to tune up the servo with the tuning software provided by dmm.
I tune it to rigid in the tuning section with before i tune it to be standard.
So the the problem which i had is solve.
I used to work with stepper motor never with servo motor.
Now the problem is when i switch off the computer , mach 3 and the servo power everything stand still until i turn the computer, i turn on mach 3 , i push the reset button on mach 3.the z axis drop.
Luckily it have the stopper if not the ball bearing going to spread on the floor.
I already power the servo brake with 24v 3a.
Just that i need a advice on the servo motor diagram , how to wire it properly, or as long that the z axis wont fall.
Thank you.
Sent from my SM-N950F using Tapatalk
When you hit the Estop the Power should then be turned off for the Brake, Power should be off the Brake all the time until the servo main Power is turned on
So Power off Brake ON Power ON Brake OFF This is normally controlled by a contactor so when you power up your servos the Brake is released ( Contactor turns ON supplies Power to the Break ) and when the servo drive is turned OFF, the Power to the Brake is also turned OFF
That is a heavy head I'm surprised it does not have a counter weight to balance the load
