585,992 active members*
6,052 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Need help with g-codes for my CNC mill, I'm new and bad at it any help is appreciated
Page 1 of 2 12
Results 1 to 20 of 38
    Question Need help with g-codes for my CNC mill, I'm new and bad at it any help is appreciated
    I'm trying to mill something right now that involves a tool change(needs to be a manual one) and whenever I start the mill it immediately stops and says that the "T" code is incorrect. Again I know little to nothing about codes so any help is appreciated.
    this is what some of it looks like now.
    ; T2 D=0.125 CR=0.0625 - ZMIN=-0.015 - ball end mill
    ; T4 D=0.1875 CR=0 - ZMIN=-0.35 - flat end mill
    ; T5 D=0.25 CR=0.125 - ZMIN=-0.0491 - ball end mill
    N0 G90
    N1 G17
    N2 G70
    N3 G53 G0 Z0
    ; Ramp1
    N4 T4 M6
    N5 T5
    N6 S5000 M3
    N7 G54
    N9 G0 X0.1255 Y0.7255
    N10 G43 Z0.6 H4
    N11 Z0.0604
    N12 G1 Z0.0187 F40
    N13 X0.1257 Z0.0155
    N14 X0.1266 Y0.7256 Z0.0123
    N15 X0.128 Y0.7257 Z0.0094
    N16 X0.1298 Y0.7258 Z0.0067
    N17 X0.1321 Y0.726 Z0.0044
    N18 X0.1348 Y0.7262 Z0.0025
    N19 X0.1378 Y0.7264 Z0.0011
    N20 X0.1409 Y0.7267 Z0.0003
    N21 X0.1442 Y0.7269 Z0
    N22 G3 X0.1614 Y0.747 I-0.0014 J0.0187
    N23 G1 X0.1598 Y0.7681 Z-0.0001 F20
    N24 X0.1593 Y0.775
    N25 X0.1574 Y0.8164 Z-0.0004
    I'm using HSMworks.
    15362
    Re: Need help with g-codes for my CNC mill, I'm new and bad at it any help is appreci
    Quote Originally Posted by Openstarling694 View Post
    N0 G90
    N1 G17
    N2 G70
    N3 G53 G0 Z0
    ; Ramp1
    N4 T4 M6
    N5 T5
    N6 S5000 M3
    N7 G54
    N10 G43 Z0.6 H4
    N11 Z0.0604
    N12 G1 Z0.0187 F40
    N13 X0.1257 Z0.0155
    N24 X0.1593 Y0.775
    I'm using HSMworks.
    T4= Tool 4 you can only call ( 1 ) Tool in your program you have more than one T call so will be a problem
    (T2 D=0.125 CR=0.0625 - ZMIN=-0.015 - ball end mill ) Use parentheses
    (T4 D=0.1875 CR=0 - ZMIN=-0.35 - flat end mill )
    (T5 D=0.25 CR=0.125 - ZMIN=-0.0491 - ball end mill )
    N0 G90
    N1 G17
    N2 G70 ( Remove the G70 )
    N3 G53 G0 Z0 ( Remove the G53 )
    ; Ramp1 ( remove the Ramp )
    N4 T4 M6
    N5 T5 ( Remove the T5 )
    N6 S5000 M3
    N7 G54
    Mactec54
    N0 G90
    N1 G17
    N4 T4 M6
    N6 S5000 M3
    N7 G54
    Thank you, I'll try this out and see how it works, I'm guessing that I also need to fix the other tool changes as well.
    (Update) it's still stopping in the same place, I'm not sure if I did it wrong or if its something else.
    (T2 D=0.125 CR=0.0625 - ZMIN=-0.015 - ball end mill)
    (T4 D=0.1875 CR=0 - ZMIN=-0.35 - flat end mill)
    (T5 D=0.25 CR=0.125 - ZMIN=-0.0491 - ball end mill)
    N0 G90
    N1 G17
    N3 G0 Z0
    N4 T4 M6
    N6 S5000 M3
    N7 G54
    15362
    Yes if they look like this then yes, any comments need to have parentheses at each end or this will be a problem also ( )
    Beginning and end of the program needs % also some controls don't need it but most do %
    A safety line is normal at the beginning of a Program
    G90 G40 G17 G80 ( can be in any order )
    Program Here
    End
    G0Z3. ( Or where ever you want the Z Axes to retract too )
    G53X0Y0. ( X and Y can also be where you want the each Axes to go )
    M5
    M30
    Mactec54
    Program Here
    End
    M5
    M30
    I have done all of these things already and still nothing has changed, I'm sorry to keep asking more and more questions but could there be anything else that I could fix, I also changed the tool numbers not sure if that will affect it or not.
    first tool change
    (knuck bottle opener test)
    (T1 D=0.125 CR=0.0625 - ZMIN=-0.015 - ball end mill)
    (T2 D=0.1875 CR=0 - ZMIN=-0.35 - flat end mill)
    (T3 D=0.25 CR=0.125 - ZMIN=-0.0491 - ball end mill)
    N0 G90
    N1 G17
    N3 G0 Z0
    N4 T2 M6
    N6 S5000 M3
    N7 G54
    N10 G43 Z0.6 H4
    second tool change
    N24193 Z0.08 F40
    N24194 G0 Z0.6
    N24196 M5
    N24197 G53 Z0
    N24198 M1
    N24199 T3 M6
    N24201 S5000 M3
    N24202 G54
    N24204 G0 X1.9061 Y0.3243
    N24205 G43 Z0.6 H5
    N24206 Z0.2
    third tool change
    N24475 Z0.2
    N24476 G0 Z0.6
    N24478 M5
    N24479 G53 Z0
    N24480 M1
    N24481 T1 M6
    N24483 S5000 M3
    N24484 G54
    N24486 G0 X0.4355 Y1.5
    N24487 G43 Z0.6 H2
    N24488 Z0.2
    N24489 G1 Z0.065 F40
    Sep 2011
    25
    What kind of machine and control are you using?
    Some machines require the tool# and M6 on separate lines, some don't use the M6. It looks like you're 2nd T# is a pre-call for the next tool.
    15362
    first tool change
    N0 G90
    N1 G17
    N3 G0 Z0
    N4 T2 M6
    N6 S5000 M3
    N7 G54
    N10 G43 Z0.6 H4 ( T2=H2 )
    second tool change
    N24193 Z0.08 F40
    N24194 G0 Z0.6
    N24196 M5
    N24197 G53 Z0 ( G0Z0 )
    N24198 M1
    N24199 T3 M6 ( T3M6 must match G43 line H3 )
    N24201 S5000 M3
    N24202 G54
    N24205 G43 Z0.6 H5 ( H5 is incorrect has to be the same as the Tool number T3=H3 )
    N24206 Z0.2
    third tool change
    N24475 Z0.2
    N24476 G0 Z0.6
    N24478 M5
    N24479 G53 Z0 ( G0Z0 )
    N24480 M1
    N24481 T1 M6
    N24483 S5000 M3
    N24484 G54
    N24487 G43 Z0.6 H2 ( Tool T1=H1 )
    N24488 Z0.2
    No you have not you don't want G53 in your program anywhere, not configured like this any way
    You have to change all your H numbers to the same as the tool number
    Mactec54
    Dec 2008
    3109
    On some controls G53 is a one-shot use of the machine co-ord system.... so if the control can read G53 codes, and, you have proved that it does work by MDI... there should be no problem keeping it in your program. ie G53Z0 is go home fast to the machine Z zero position.
    As for H numbers matching the tool #... that should be a "standard" you should adopt..... it won't stop a program from running
    My 2cents.... sequence number zero (N0) may not be a legit range.
    ... best advice would be to single step the program to stop at the offending line.... then delete/modify items one at a time
    .... if you run a program. your machine may read ahead many lines, making it harder to isolate any problem code.
    If your machine requires you to manually toolchange.... M6 is an auto operation.... replace it with M00.. this makes the running program stop... forcing you to do something ... then cycle start to continue.
    15362
    Quote Originally Posted by Superman View Post
    The control he is using quite often will not run the G53 so is better off not being in the program a G53 does not move any different than a G0 move
    His control will stop for a Tool change T1M6 is fine
    Mactec54
    Dec 2008
    3109
    You seem to know what his machine & control is... want to let the rest of us know ? (the question was asked, but not answered)
    I did say "some controls".... and if the actual code worked...it is his choice to keep using it, not yours.
    I understand you have a lot of experience up your sleeve, but compelling a newbie to do jt to your coding method is not allowing him to develop on his own. There is quite often alternative methods
    15362
    In testing the G53 worked so not a problem to have it in his program,
    I'm just guessing like everyone else, but Mach3 I would say is his control a little out of your league, I just run his program through 2 different controls and it will run if he corrects it as I posted
    When someone is learning they should start with the basic codes or know what the likes of G53 does, How it needs to be formatted in a line for it to work correct, so a standard G-Code like ( G0 ) is the simplest form of G-Code to know and what it does, Just the 2 letters tell you what it is going to do ( G0 )
    Depending on how it is used in Mach3 it will either pass it by and not do that line which is bad, or just stop some of these control just won't run the program from the start if it has a Code that it does not like
    You need to have used and installed these controls to make the comments you do
    Mactec54
    I'm new to the CNC world and I'm running a Cincinnati Lancer mill with G code and I run Gibbs Cam software which is extremely easy to use. You may want to look into it.
    15362
    Quote Originally Posted by Problem_child View Post
    Yes Gibbs is good been using it for more than 20 years, but not many can pay the yearly maintenance little along buy the basic software package
    Mactec54
    Apr 2003
    3578
    you stated that tool change has to be a manual tool change. we have not heard what the machine is. this could be a desktop mill or a Bridgeport with a Acromatic control and no tool changer so some do not want any T call outs. or they want a T1 for all or T0. For me I would just removed the T call out and see if it moved forward.
    Cadcam
    It's Intelitek BenchMill 6100
    Quote Originally Posted by Turning_Guy View Post
    I'm using an Intelitek BenchMill 6100, and also CNCBase on a laptop that's connected to the mill.
    Quote Originally Posted by cadcam View Post
    I took out the T call outs and so far its working, I haven't gotten to any of the tool changes yet, but will find out how it works.
    15362
    So your machine use's regular G-Code so what I gave you will run on your machine nice machine did you get it new
    Mactec54
    Yes, and the part came out really well, it is new, but my school owns it, I could never afford that kind of thing on my part-time Home Depot salary. Also thank you to everyone who helped me out with this, I've learned a lot more about gcodes from it.
    Oct 2008
    2100
    Program Here
    End
    M5
    M30
    If manually inserting a retract for safety I prefer to enter a G53 for absolute machine position rather than G00 which is in the current coordinate offset. The negative for using a G53 is that it moves at the last F speed, so its also good to add an F value. G53 Z0 F300. On some machines I used to use a G28 or a G30, but now I have multiple machines different setups. I actually prefer to modify my M30 macro on each machine to include a G53 Z0 F300 along with an extra M5 M9 just in case. G28 and G30 don't perform exactly the same on every control program. For one machine I rewrote the post processor to insert all kinds of safety and tool change position code. On others I did that in the tool change macros.
    Bob La Londe
    http://www.YumaBassMan.com
Page 1 of 2 12
  1. Replies: 7
    Last Post: 12-09-2017, 01:08 PM
  2. New steel mill/router design. Feedback appreciated.
    By geekness in forum CNC Wood Router Project Log
    Last Post: 06-19-2014, 05:24 PM
  3. Replies: 4
    Last Post: 08-19-2010, 09:04 PM
  4. roland camm3 mill any info appreciated
    By m8kingit in forum Benchtop Machines
    Last Post: 08-23-2008, 03:38 PM
