585,735 active members*
4,745 visitors online*
Page 1 of 4 123
Results 1 to 20 of 77
    Jan 2015
    39
    Jake's 4x8 CNC Build
    Greeting from the Olde North State, and welcome to my first CNC router build. This will be an all steel welded table with a 5hp ATC spindle (hopefully), Clearpath's or servos, linear rails, and rack and pinions . The plan right now is to have the gantry and frame machined at a shop (TBD). This will be a machine for cutting out cabinet parts primarily. I have been learning Fusion 360 for the design, and decided to start with the Z-axis and build out from there. I'm planning to buy the motion parts from Automation Overstock, but I am open to suggestions for everything. I'm looking for good value readily available components that could be upgraded later if possible.
    Some details on the Z:
    BLH 20mm guides
    20mm x 500mm rolled ballscrew (5mm start)
    245mm of travel
    Z is 200mm wide
    Gantry beam 6" x 10" x 3/8"
    Questions:
    Is a 20mm ballscrew enough to handle 100 lbs. ? (spindle, plate,rails,srcew)
    Micro switches vs proximity switches? Proximity switches seem to be problematic.
    Re: Jake's 4x8 CNC Build
    Yes, a 20mm screw is plenty.
    Jan 2015
    39
    Thanks Gerry. I was planning on a 5mm pitch screw, but I read an old post where you recommended 10mm or 20mm. Will I be able to lift the Z with spindle with a 10mm pitch ball-screw? On the same note, I'm designing right now around using NEMA 34 motors and was wondering if I will be able to find drives powerful enough in that frame size?
    When I tried to mount the z to the gantry beam I realized it was getting pretty narrow. I redesigned it using 10" wide 1/2" thick plate. I am planning to use the same plate for the gantry beam and weld up my own rectangle tube. Seems like that is what Onsrud has moved to.
    A lot of people use 5mm pitch screws on the Z axis.
    It just depends on the performance you're looking for.
    10mm should work too. There are formulas to determine how much torque you need to lift a given amount of weight at a given acceleration.
    If you're worried, stay with the 5mm.
    Jan 2015
    39
    Ripped the band aid off yesterday and ordered all the steel for the base and gantry. My design has changed once again and I'm going with an open base. Space is at a premium for all of us and the thought of all that dead space underneath bothered me. Pretty much 3/8" thick everywhere except the gantry, it will be 1/2". The table under the spoil board will be 1/4". Howard Steel is going to shear all the leg plates for me and break down the 20 footers into manageable lengths. I have been on the Oriental Motor website trying to use their motor sizing guides and it seems like I will have enough room in the legs to drive the gantry. I'm still not sure what travel speed I should shoot for with a DIY machine. 1500 ipm? I saw some of the professional machines are 2000 standard. Anyways, everything should be ready for pick up on Tuesday and I still have a lot of details to fill in before I start welding.
    Jul 2018
    6321
    Hi Jake - I don't think the stiffness of your Z axis plate matches the capability of the machine, especially when its down. The rest looks very good. It needs to be quite a bit thicker. Look up the Maximus thread I spend a lot of time looking at the Z axis stiffness in that. Do you have someone to machine the gantry after you weld it? It will change shape quite a bit with those long welds.
    If you send me the step model of the columns, bearings (or zip it and publish here) , gantry and z axis I'll run it in an FE program to see how stiff it is. Put it in the max down position, with Z in the midway gantry position....Do you want to cut aluminium ? Peter
    Are you planning on direct driving the pinions? You really want to use gearboxes.
    With a 5HP spindle, your cutting speed will probably be limited to 500ipm or so. And acceleration is more important than top speed. 1500IPM would be useless, if it takes a while to get there.
    Jul 2018
    6321
    Hi Jake - Can I ask where did you get the dimensions for the drivescrew components? Nut, nut housing, coupling and support bearings? been digging around trying to find them, no luck yet. Peter
    Jan 2015
    39
    I am open to ANY motor option at this point. Geared or direct, I just want to make sure I leave enough space for them. The gantry is weighing in at close to 800lbs. On the IPM, I got those numbers from Onsrud. How do they (or anyone) calculate that speed? In one direction or two, three? With the bit in the material?
    I too think that plate is too long and thin. The Z design has been pretty frustrating for me. If you look at the first picture in this tread I had the rails on the Z "sled" for stiffness. I changed this to blocks on the Z sled in some sort of attempt in faster management. I was trying to avoid using flange style carriages to keep rails as far apart as possible. At a minimum I plan to add side and maybe middle stiffeners to the Z sled. Steel comes in 20 foot lengths and the plan is to use the leftover drops from the gantry (10" x 1/2") for the Z plate and gantry legs (top and bottom).
    This will machine will cut plywood and melamine only. I have found a machine shop 45 minutes away with a big bridge mill but I have not been able to find anyone to do the street relief as of now. I will download the .stp file and send it your way. Thanks!
    On a side note, how do I upload pictures that will display as a thumbnail until clicked? Just trying to keep things tidy.
    Attached Files Attached Files
    ericks Guest
    Hi...i really like your design, looking forward to see this develop
    May 2005
    3920
    This is a very interesting design and looks like a lot of thought has gone into it.
    The one thing that bothers me a bit is that you apparently intend to use 3 rails on the gantry beam with one mounted 90° out from the other two. This can be an assembly issue as you now have two planes to contend with. Having the gantry machined in a good machine shop will help. However I’d seriously consider simplification, a larger beam for a two rail system with a wider distance between rails might be a better path. I’m sure you will get different opinions but I’d most certainly discuss this with the machine shop you I tend to have do the fabrication.
    May 2005
    3920
    Jake which Charlotte are we talking about here. There are shops in the Buffalo NY area that can stress relieve just about anything.
    Quote Originally Posted by JakeInCharlotte View Post
    It is the linear speed of the cutter on the path it is following.
    Don’t make the Z any higher than required for the intended usage plus a bit of clearance for usability. If the goal is to machine sheet goods having 20” of S capability just leads to an expensive machine. Given that there is no perfect value for Z axis capability.
    If plywood is the goal then excessive Z stroke isn't required. You do need to avoid too little also. By the way I’d also suggest keeping the linear motion bearings on the Y axis saddle. This way the rails are always supported as near to the working end of the tool as possible.
    Oct 2009
    733
    For this size of machine, you might maybe consider a H or U style steel "slider"?
    As a side note, would you mind to share where you got the "ball_screw_documentation.pdf" from?
    Jul 2018
    6321
    Hi Jake -Its a killer machine for timber. Minimise your Z travel and make the tool plate a U section. Webs either side of the spindle. Once you redesign I can do some numbers for the stiffness. Your gantry is mega stiff and it would be good to match the Z axis stiffness to this component. Peter
    Aug 2018
    621
    To me it looks like the spindle mount would add a lot of rigidity to the z mounting plate if it's going to be made like the drawing. It looks like the spindle is making full contact with the back plate so it's not 1/2 inch material anymore, it's 1/2" plus the spindle and mounting bracket. Maybe I'm way off in what I'm seeing?
    Dan
    Jul 2018
    6321
    Hi NTL - The spindle mount only stiffens the bottom of the plate. Once the Z axis moves down past a certain point its only 1/2" thick plus the rails in stiffness. Thats why people are recommending reducing the Z axis travel or adding outside webs to the Z plate or sled as Jake is calling it. If the Z axis can be organised to take advantage of the spindle stiffness then that's very good. Peter
    Jul 2018
    6321
    Hi Jake - Did a quick calc on the plate. I have used the Maximus tool plate as a benchmark. Its equivalent thickness is 79mm. Your gantry is stiffer then maximus as well. If you use 4" or 100mm webs (using 1/2" plate) on the outside of the plate you get an equivalent thickness of 70mm I think this is about you need to do. Peter
    Jan 2015
    39
    Quote Originally Posted by davida1234 View Post
    Automation Overstock, surplus automation equipment, overstock automation devices, manufacturer overruns, linear bearings, variable speed drives, circuit breakers, contactors, starters, relays
    They are a NC company. I am also planning to get my slides from them.
    I think the Z plate will be a U shape when done.
    Quote Originally Posted by Ntl View Post
    Dan
    It will be 1/2" steel as well, but I plan to add some support on the sides for good measure.
    The one thing that bothers me a bit is that you apparently intend to use 3 rails on the gantry beam with one mounted 90° out from the other two. .
    The gantry will have only two rails. The top profile will accept the gear rack. The model I downloaded was giving Fusion a lot of troubles so I deleted it for now.
    I am looking for a good supplier for the rack. 20mm+ high?
    Charlotte NC, you know, the place all your neighbors moved to. Every fall the sports bars jockey for who can be called the the official Bill's headquarters on billboards and sports radio. Oh, and thanks for the wings idea!
    Right now the Z and gantry clear about 10" (255mm). 9-10" seemed pretty common so I went for that. Also I wanted to give myself enough room for for a gearbox if I have to go that way.
    You can tell form this pic that I still need shorten the Z Plate. I will probably add a Lip to the outside edge of the leg so its not unsupported. Maybe 1" wide.
    Peter--- Right now I have 65mm between the faces of the plates. I was thinking ribs about 1/4 - 3/8 x 1-1/2" wide on the outside edges.
    Steel yard called this afternoon. Tuesday turned into "We'll call you early next week" 2500lbs of steel this order. Thats one heck of a boat anchor.
    Aug 2018
    621
    I see it now, I didn't realize that the rails were mounted to the moving side of the z. It looks like he does have bar's mounted to the backside plus the rails. If the plate is 1/2" the rails and bar's appear to be maybe 1.5"? So he does have some bracing, but I have no idea if it would be enough.
    It's a interesting design, I don't think I've seen one that the rails move and the blocks are stationary. What are the advantages of this design vs the other way around?
    Jul 2018
    6321
    Hi Jake - Sorry not big enough. 1/2" thick and 4" high minimum. The Z Axis cantilever is the critical part of the machine don't skimp on it. It's the coal face. It's the thing that will vibrate if under stiff, it's the thing that will deflect from your huge motors and drives etc etc. Plus these webs are in free air so there is no reason not to go big. Plus it will give you something to hang the dust collection and other things that you will hang on this area over time. You have a mega machine with a wimpy Z at the moment. Need to add some steroids to it. Peter
    Thks for the ball screw catalogue very good.
    Just a thought you can screw these webs on from the sides (or screw them to the small webs you are thinking of) so you can take them off to modify them without taking the Z axis off. You will have dust collection and other things to add, so this area needs a bit of ease and flexibility to it.
Page 1 of 4 123
  1. Router home build Australia. Solid steel build
    By 80gus in forum DIY CNC Router Table Machines
    Last Post: 05-03-2020, 09:24 AM
  2. Mint's Build Aluminum/Steel Build thread.
    By FreshMint in forum Maintenance DIY Discussion
    Last Post: 10-31-2011, 04:18 AM
  3. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
