585,591 active members*
2,834 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > High Speed VFD Required
Page 1 of 2 12
Results 1 to 20 of 22
    Mar 2016
    6
    Hi - I'm looking for a VFD that will cope with 3333hz - It's to run a 200k rpm .5kw spindle.
    Any ideas on suitable models?
    M
    Dec 2013
    5717
    Re: High Speed VFD Required
    I would contact the spindle manufacturer for a recommendation. That sounds like a really special VFD.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2009
    6028
    And i thought our 60K spindles were fast. Holy smokes!
    Mar 2016
    6
    Quote Originally Posted by underthetire View Post
    Its basically a pcb drilling head, I was wondering about modifying a normal (cheap) VFD as it's only 500 Watts.
    It'll be great for my engraving.. Lol
    Mar 2016
    6
    Manufacturer has closed shop so no details about it unfortunately.
    I'll probably end up making an inverter VFD to run it.
    Dec 2013
    5717
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    91
    just thinking anyone know any VFD that can go 800hz? i need it for my atc spindle
    15362
    Quote Originally Posted by teamloks1 View Post
    There are lots that are standard 1000Hz that will suit your 800Hz spindle all from the regular sources Ebay Amazon Etc
    Mactec54
    Feb 2019
    91
    there alot chinese brand but i prefer reputable brand just now im thinking about delta
    15362
    Yes Delta is a good VFD Drive but it most likely you will find that it is made in China, most are even the top manufacturers so just with every good brand name, there are copies out there also so beware
    Mactec54
    Jan 2014
    126
    You may find it a little difficult to find high frequency output VFDs. By US export law, most VFDs and motor drives are limited to 590Hz output frequency in order to prevent the proliferation of nuclear centrifuges. Most manufacturers follow this limit, while others can apply for exceptions. I do not know how non-US laws control this.
    Btw, I've NEVER heard of a 3333Hz motor. That's insane.
    Quote Originally Posted by Vassago009 View Post
    M
    The VFD with these specifications might need to be special designed and made.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Feb 2019
    91
    yes thanks for insight i just pull the trigger for delta ms300 5.5kw 1500hz output with built in emc filter
    Aug 2009
    1570
    1000hz is Law in USA (I think) or was it Ohm's Law apply's...maybe Newton's Law...spin .. repeat..spin
    15362
    The built in EMC filter does not eliminate the Input Power Filter Required
    Mactec54
    Feb 2019
    91
    thanks for reminder and knowledge i should get 20a 3 phase emi for it
    15362
    No this depends on the amperage required for your VFD Drive check the max output amps of the VFD Drive and double it that will be your Filter and Breaker requirement
    Mactec54
    Feb 2019
    91
    i just check my motor only need 4.5kw 9.1a 380v ..my drive max output is 22.5a factory setting should i get 50a emi filter?
    15362
    Your spindle motor has to be 220v/240v you can not run it if it is 380v when you only have 240v supply check this spec first should be around 14A to 15A for the spindle at 220v so 30A should be fine, the VFD Drive is larger capacity which is good
    so then we can go of the Spindle max current draw
    Mactec54
    Feb 2019
    91
    im from malaysia i buy 3 phase 5.5kw drive in here we are using 230v for 1 phase and 415v for 3 phase owh here is my motor spec
Page 1 of 2 12
  1. high friction spoil board alternativ required
    By nicubila in forum Other Machine Topics
    Last Post: 08-18-2015, 04:02 AM
  2. Replies: 7
    Last Post: 12-07-2014, 03:23 PM
  3. Nema34 required to get high torque at 30-120 RPM
    By Fundacion in forum Stepper Motors / Drives
    Last Post: 11-28-2014, 01:21 AM
  4. Coupling ideas for high speed and high torque
    By Azalin in forum Benchtop Machines
    Last Post: 07-24-2014, 11:38 PM
  5. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
