585,754 active members*
3,915 visitors online*
Results 1 to 2 of 2
    Jun 2018
    18
    AW708C Lite Controller - network problems
    Hi folks,
    So I just got this controller installed on my Chinese laser cutter replacing an M2 controller board.
    Everything works well which suggests to me the wiring is ok.
    But I have 2 issues:
    The main one is that I can't seem to figure out how to connect the controller to my network.
    I have changed the ip address under network settings accordingly and I can connect to it if I connect directly to my computer and bridge the connection with the WiFi. However, if I connect directly to the router/network switch, nothing happens.
    What could I be missing in this setup?
    The second issue is with regards to homing and limit switches. Seems like the controller is unable to home to the limit switch and it just assumes its starting position is always home. But... Everytime it startsup/resets, it moves diagonally down a few mm meaning your bed size is reducing each time.
    If you power on with the limit switches depressed, it moves in the opposite direction...
    The switches are connected to the -ve terminal.
    Thanks guys!
    Nov 2008
    644
    Re: AW708C Lite Controller - network problems
    I’m using a Vonets VAP11G-300 on my AW708C. Works great then I decided to go to a commonly sold WIFI extender to get a better signal. Has a couple Ethernet ports to plug into. Could not get it to connect no matter what I tried. No communications. Plug the Vonets in using same settings and it works. I gave up on the extender
  1. AWV708C Lite DSP Controller Installation and Impressions
    By cowanrg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-17-2019, 05:07 PM
  2. AWC708C Lite network problem
    By wolfmodels in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-11-2017, 05:57 AM
  3. windows 7 and XP network key problems
    By timf in forum EdgeCam
    Last Post: 08-22-2012, 06:18 PM
  4. Problems with Fanuc 11M/NCnet Lite
    By FuddMcDee in forum DNC Problems and Solutions
    Last Post: 04-03-2012, 03:14 AM
  5. Fanuc 21i network problems
    By questme in forum Fanuc
    Last Post: 07-15-2008, 03:56 PM
