585,973 active members*
4,199 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Stepper motor, voltage and inductance
    Aug 2013
    7
    Question Stepper motor, voltage and inductance
    Hello Dears,
    I have a burned-out steper motor : 86BHH76-400B-35J with technical data: Current: 4A, Inductance: 3.5 mH, Resistant: 0.62 Ohm
    Can I replace it with 85BYGH450A-06-05J - Current: 4A, Inductance: 2.3 mH, Resistant: 0.5 Ohm
    The difference are Resistant and Inductance.
    My power supply is 70V AC and stepper driver dma860h. Machine works on low feed rate.
    Feb 2008
    644
    Re: Stepper motor, voltage and inductance
    Looks like it should work fine (same current/torque)
    Lower inductance so maybe a bit better high speed performance
    Lower resistance so less power dissipation
    Aug 2013
    7
    Thanks Dear,
    are 70 Volts for the Inductance: 2.3 mH OK?
    Feb 2008
    644
    Quote Originally Posted by smart81bg View Post
    Thanks Dear,
    It should be fine, ripple current will be higher but I'm pretty sure the
    DMA860 has a 50 KHz or so switching frequency so the ripple will be minmal
    Aug 2013
    7
    Quote Originally Posted by PCW_MESA View Post
    Thanks I will try, Hope will no damage anyting, Yes it is 70V AC.
  1. Voltage-Inductance-Amps preformance
    By kiwicam in forum Gecko Drives
    Last Post: 05-22-2015, 10:15 AM
  2. Measuring stepper motor inductance
    By PEU in forum Stepper Motors / Drives
    Last Post: 03-12-2013, 03:45 AM
  3. Ideal Voltage for Inductance.
    By xrayxray in forum Stepper Motors / Drives
    Last Post: 01-22-2012, 09:36 PM
  4. Replies: 6
    Last Post: 10-27-2009, 01:36 AM
