586,011 active members*
4,215 visitors online*
    Aug 2016
    24
    Lightbulb Maho speed second gear limited 800rpm
    Hello i'm having trouble again with my maho 1600s ,
    this machine has philips 532 controller and indramat drive modules,
    when i run the machine in M41 , first gear is selected, it's running up to 700rpm
    then when i demand higher rpm or M42, the second gear is active and should run from 700rpm up to 6000rpm,
    the problem is that the spindle speed is stuck on 800rpm, i check the small camshaft on that indicate the gearposition 1 , 2 or neutral, this is working fine,
    i tested the motor , cables, connectors, and finally i found out when that the 2 contacts operated by the gearcams go to the controller as input but also to the indramat spindle drive input wich are described as Limit 1 and limit 2 input,
    so in second gear both are operated and both inputs high, when i remove the first limit of the Limit 1 input on my indramat it works correct again and runs the right speed again and not stuck on the 800rpm,
    so i tought that the speed limit was in the parameters of the indramat,.... i checked the parameter A12 up to A18 that should be preset limit speeds,
    all of them are the value 9999 , so also this is not the problem , however when i disconnect the input of the cam it runs fine.....
    so after searching houres i hope some of you can help me out with this and help me find what can cause this problem and whats the reason activating the limit?
    Aug 2016
    24
    Re: Maho speed second gear limited 800rpm
    now found out that machine can run max 800rpm when its in setup mode?
    but i dont find out what causing this setup mode, exept emergency stop circuit of the cabine doors, but the safety circuit seems ok ,
  1. VM17 Spindle speed limited
    By Ozfab in forum Milltronics
    Last Post: 03-04-2020, 07:12 AM
  2. 12Z High Low speed gear selector broke
    By Steelmesh in forum Charter Oak Automation Support Forum
    Last Post: 06-20-2016, 02:46 AM
  3. BF20 Low Speed Gear Broken...doh
    By zerodegreec in forum Benchtop Machines
    Last Post: 10-02-2010, 04:40 AM
  4. Is cutting speed limited to Z-axis speed
    By Beefy in forum Waterjet General Topics
    Last Post: 02-13-2010, 11:06 PM
  5. 2-Speed Gear Box a Necessity?
    By JMFabrications in forum Haas Mills
    Last Post: 03-21-2008, 09:47 AM
