585,735 active members*
4,692 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > how to reset after hard limit triggered
    Mar 2011
    357
    I have a DIY router using Arduino/GRBL. I have hard limits set up. When I trigger a hard limit it goes into alarm and I can't figure a way to get out of it other than powering down my poser supply and manually moving the machine off of the switch.
    Is there a better way?
    Nov 2005
    222
    Re: how to reset after hard limit triggered
    I have that problem when I am jogging while machine is not homed and the soft limits are not active. I do this to get access to the ball nuts for lubricating them. Right now I just short the limit switch with a test lead. I'm thinking about putting some momentary NO push button switches in parallel with the limit switch that I could push and hold while I jog off the limit switch.
    John
    1943
    $X command overrides the alarm lock allowing you to jog off of the switch
    Mar 2011
    357
    I have tested this. the $X overrides the requirement to home the machine after connecting but it will not override a hard limit alarm lock.
    Mar 2015
    409
    Quote Originally Posted by tkms002 View Post
    When GRBL hits a limit switch, it stops all steppers and (exact) positions are lost. You have to reset the GRBL controller by pressing reset on the arduino or just disconnect and connect again. After that, you can use the jog buttons.
  1. Limit Switch Triggered! IS NOT!!
    By Mr.Chips in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2020, 12:18 PM
  2. Limit switch triggered
    By redbone1 in forum Mach Software (ArtSoft software)
    Last Post: 12-16-2017, 02:59 AM
  3. Limit switch triggered
    By bohica in forum Charter Oak Automation Support Forum
    Last Post: 12-12-2015, 01:28 PM
  4. limit switch triggered
    By Claude Boudreau in forum Machines running Mach Software
    Last Post: 04-29-2012, 01:06 PM
  5. Limit Switch Triggered??
    By H2ODiver in forum Mach Mill
    Last Post: 02-22-2007, 06:48 PM
