586,011 active members*
5,135 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > attempting first CAM on fusion 360
Page 1 of 2 12
Results 1 to 20 of 28
    Mar 2011
    357
    Trying to create a tool path to mill out the holes in this part.
    Why an I getting these errors?
Name:	fusion error.jpg
    What other information is needed and how do I get it for you?
    Nov 2014
    724
    Re: attempting first CAM on fusion 360
    It would be best if you upload your file (file, export).
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Dec 2013
    5717
    Those errors won't stop the G code from posting. Fusion is notifying you that it was not able to do quite what you told it to, and it is making a correction. I have never seen that error, but best guess is that you tried to set a plunge or start point that is out of the tool path.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2011
    357
    Tried just taking a lot of defaults but I would sure like to know what I screwed up.
    I did a file export from the MANUFACTURE menu.
    When I tried to attach the file I get this
    Attachment 419548
    Mar 2016
    22
    Zip the file.
    There are limited file extensions allowed to be uploaded!
    Regards,
    Arie.
    Mar 2011
    357
    on another note, why is it that every F360 CAM intro vid I look at shows a CAM workspace but in my copy I see a MANUFACTURE workspace??
    Dec 2013
    5717
    Quote Originally Posted by tkms002 View Post
    They changed that process name a few updates ago. Surprised me too.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2011
    357
    zipped file attached
    Nov 2014
    724
    I couldn't open the file, said it wasn't a valid zip file.
    David
    David
    Romans 3:23
    Mar 2011
    357
    ok try this one
    Attached Files Attached Files
    Jun 2018
    84
    ok try this one
    I didn't get any error messages. Simulation looked good.
    Mar 2011
    357
    uugh sorry that one did not have the error tool path in it.
    Please take a look at this one.
    Also in the previous one it only cut to .475 and the stock thickness is .5. I dont understand why.
    Nov 2014
    724
    The reason it's not boring all the way through is because you have Stock To Leave set at 0.02". Turn that off and it goes all the way through. Not sure on the plunge outside of stock message, only had a minute to look.
    David
    David
    Romans 3:23
    Oct 2010
    171
    Well, on this last file you uploaded, you are using a the "Pocket" method to bore 4 holes. (there is no machining shows on the slots)
    On the 4th tab in the "Pocket" routine you are using, you have "Stock to Leave" checked, and difalkner pointed out that you are leaving .020" stock axially AND radially. Even if you change that, you will probably still get a warning, as there simply is "almost no room to move" inside that 5/16" hole with a 1/4" end mill trying to pocket it.
    Those 4 holes should be drilled if at all possible, and if you insist on machining them --grin-- with that .250" end mill, then the correct method is to use the "Bore" strategy. I've added that method as another process, and re-uploaded the file.
    Oct 2010
    171
    OK... uploading another file for you to look at.
    I'm making the assumption that you would like to use that 1/4" end mill for most everything, so.... I created a way to cut the slots using 3 different methods:
    - "Bore" the ends of the slots
    - "Trace" the centerline of the slots, ramping down but staying on the centerline
    - "Profile" the outside wall with a finish pass
    I also added a sketch with a single circle on it at the end of the one slot I machined, so that I could select the center of that circle as the entry point when doing the Profile pass (i.e. plunge straight down to full depth).
    All your feed rates appear way too high to me, so I'd recommend dropping those way back, at least initially.
    If nothing else, you can see 3 different methods to cutting a portion of the slots. There are other ways to do it... you could profile and just ramp down along the perimeter, you could "bore" one end and then use adaptive clearing to remove 98% of the material and then just a quick profile pass. Lots of ways to skin the cat! The approach I would probably take would be to set up a 5/16" drill in another holder, and drill one end of each slot, and the 4 holes. Then go back and adaptive clear the slots and run a quick profile pass to clean the outside.
    Fire away if you have questions.
    PM
    Mar 2011
    357
    Thank you all for the help. Much appreciated.
    I will take a look and give it all a try.
    Mar 2011
    357
    Quote Originally Posted by precisionmetal View Post
    PM
    Why do you think my feed rates are high? I am only cutting MDF at the moment and it seemed to cut it fine at 60 IPM. I was thinking about going faster. Please explain.
    Oct 2010
    171
    It may be perfectly fine in a straight line or a larger profile, but programming 60"/min in something like "boring" a 5/16" hole with a 1/4" end mill might overwhelm your your machine's ability to follow the programmed path.
    Mar 2011
    357
    Got it what speed would you suggest for the slots and the holes?
    Oct 2010
    171
    No way of knowing. You're cutting MDF on ... is it a CNC router table? Not sure what cutter you're using. If you're able to cut 60"/min in a straight line without any issues, then you "might" need to just slow it down a bit for profiling the insides of those slots. That's a tight corner to make if you look at what the centerline of the cutter has to do to make that corner.
    I'm sure you have a lot more experience with MDF than I do, so you will have a good "feel" for how fast you can cut it. I'm thinking more about what your machine has to go through to make a tight arc/circle at high feed rates. :-)
    PM
Page 1 of 2 12
  1. I'm attempting the 3D Skull project in Aluminum.
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 08-02-2017, 04:11 PM
  2. attempting to tap AR500
    By hatchmar in forum MetalWork Discussion
    Last Post: 11-03-2016, 10:38 AM
  3. Attempting to Make a Mold in BobCAD V26
    By fishinmachinist in forum BobCad-Cam
    Last Post: 02-29-2016, 04:27 PM
  4. Attempting Wireless With a 640M
    By Dr_Bob in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-27-2012, 05:55 PM
  5. Attempting to learn Madcam
    By shippman in forum MadCAM
    Last Post: 03-30-2010, 07:22 PM
