585,722 active members*
4,314 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > attempting first CAM on fusion 360
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Mar 2011
    357
    Re: attempting first CAM on fusion 360
    Quote Originally Posted by precisionmetal View Post
    No way of knowing. You're cutting MDF on ... is it a CNC router table? Not sure what cutter you're using. If you're able to cut 60"/min in a straight line without any issues, then you "might" need to just slow it down a bit for profiling the insides of those slots. That's a tight corner to make if you look at what the centerline of the cutter has to do to make that corner.
    I'm sure you have a lot more experience with MDF than I do, so you will have a good "feel" for how fast you can cut it. I'm thinking more about what your machine has to go through to make a tight arc/circle at high feed rates. :-)
    PM
    yes, A DIY CNC Router table.
    I have manual router experience but I have no idea how fast I am pushing it. As you said, it is by feel.
  2. #22
    Mar 2011
    357
    Quote Originally Posted by difalkner View Post
    The reason it's not boring all the way through is because you have Stock To Leave set at 0.02". Turn that off and it goes all the way through. Not sure on the plunge outside of stock message, only had a minute to look.
    David
    I dont get it. I have opened both the files I sent you and I dont see STOCK TO LEAVE turned on in either one. When I do click that box it shows .004.
    Attachment 419696
Name:	stock to leave2.jpg
  3. #23
    Nov 2014
    724
    Quote Originally Posted by tkms002 View Post
    Attachment 419696
    I just downloaded your file in Post #12 again and opened it to the Passes Tab. It shows Stock To Leave set at 0.02".
Name:	Xaxis idler plate2 - stock to leave.jpg
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
  4. #24
    Mar 2011
    357
    David
    but I have not run that tool path. I ran the first tool path. The profile pass to cut out the part and it does not have the stock to leave checked but still only goes .475 deep.
    Attachment 419706
    Also, in the generated G-code I see several places where .475 is listed. What are they doing?
    g-code is attached.
  5. #25
    Mar 2011
    357
    ok My bad. I must have run a different program.
    I re programmed one just now and it cut all the way through. I made sure I did not have stock to leave checked.
  6. #26
    Mar 2011
    357
    when I ran my last program I first removed the beginning g28 and the line with M6 in it.
    After the cut was complete it sliced an angle through the part as it was going back to my home. I am assuming this was because of the last G28 in the code?
    Code is here
    (1001)
    (T1 D=0.25 CR=0 - ZMIN=-0.5 - flat end mill)
    G90 G94
    G17
    G20
    G90
    (2D Contour4)
    M9
    S24000 M3
    G54
    M8
    G0 X-3.692 Y-4.875
    Z0.6
    Z0.2894
    G1 Z-0.25 F13.12
    X-2.625 F60
    G3 X-2.5 Y-4.75 J0.125
    G1 Y-3.25
    G3 X-2.625 Y-3.125 I-0.125
    G1 X-3.692
    G2 X-4.0167 Y-2.9375 J0.375
    G3 X-4.125 Y-2.875 I-0.1083 J-0.0625
    G1 X-7.125
    G2 X-7.5 Y-2.5 J0.375
    G1 Y-1.25
    G2 X-7.125 Y-0.875 I0.375
    G1 X-0.875
    G2 X-0.5 Y-1.25 J-0.375
    G1 Y-6.75
    G2 X-0.875 Y-7.125 I-0.375
    G1 X-7.125
    G2 X-7.5 Y-6.75 J0.375
    G1 Y-5.5
    G2 X-7.125 Y-5.125 I0.375
    G1 X-4.125
    G3 X-4.0167 Y-5.0625 J0.125
    G2 X-3.692 Y-4.875 I0.3248 J-0.1875
    G0 Z0.2
    Y-3.125
    G1 Z0.0394 F13.12
    Z-0.5
    G2 X-4.0167 Y-2.9375 J0.375 F60
    G1 X-7.125
    G1 Y-1.25
    G1 X-4.3
    X-4.25 F15
    X-4.1697 Z-0.4599 F60
    X-4.125 Z-0.4375 F15
    X-3.875 F60
    X-3.75 Z-0.5 F13.12
    X-0.875 F60
    G1 Y-3.7
    Y-3.75 F15
    Y-3.8303 Z-0.4599 F60
    Y-3.875 Z-0.4375 F15
    Y-4.125 F60
    Y-4.25 Z-0.5 F13.12
    Y-6.75 F60
    G1 X-3.7
    X-3.75 F15
    X-3.8303 Z-0.4599 F60
    X-3.875 Z-0.4375 F15
    X-4.125 F60
    X-4.25 Z-0.5 F13.12
    X-7.125 F60
    G1 Y-5.5
    G1 X-4.125
    G1 X-2.625
    G1 Y-3.25
    G1 X-3.692
    G0 Z0.6 is this the retract height before the rapid to home? stock is only .5 thick
    M9
    G28 G91 Z0
    G90
    G28 G91 X0 Y0
    G90
    M30
    Attached it the fusion file
    here is a pic of the damage
    Attachment 419718
    how do I keep that from happening?
  7. #27
    Nov 2014
    724
    Got it what speed would you suggest for the slots and the holes?
    I regularly cut 1/2" Baltic Birch with a 1/4" compression bit running 18k rpm, plunge to 0.25" depth of cut, and typical feed rate of 175 ipm - no issues at all. Just cut a Longworth chuck an hour ago using these settings. I cut the center hole, finger holes, slots, and outer profile at the same setting.
    Attachment 419720
    David
    David
    Romans 3:23
  8. #28
    Dec 2013
    5717
    Code is here
    (1001)
    G1 X-3.692
    M9
    G28 G91 Z0
    G90
    G28 G91 X0 Y0
    G90
    M30
    Try this, set G28 Safe Retracts = No :
    Then run an air cut and see if it fixed the problem.
    Jim Dawson
    Sandy, Oregon, USA
Page 2 of 2 12
  1. I'm attempting the 3D Skull project in Aluminum.
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 08-02-2017, 04:11 PM
  2. attempting to tap AR500
    By hatchmar in forum MetalWork Discussion
    Last Post: 11-03-2016, 10:38 AM
  3. Attempting to Make a Mold in BobCAD V26
    By fishinmachinist in forum BobCad-Cam
    Last Post: 02-29-2016, 04:27 PM
  4. Attempting Wireless With a 640M
    By Dr_Bob in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-27-2012, 05:55 PM
  5. Attempting to learn Madcam
    By shippman in forum MadCAM
    Last Post: 03-30-2010, 07:22 PM
