i need help
okuma osp 300 atc arm stand by on position
help
need ts parameters how opening:banana:
i need help
help
hi / if the arm stopped midway during change sequence, you need to reverse manually the sequence; there shoud be a black button on the panel, from where you should select atc and then reverse until current step = 0
unfortunately, i can not share photos/printscreens at this moment
also, what happened ? what caused the stop ? kindly
