586,011 active members*
4,212 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma osp 300 atc arm
Results 1 to 2 of 2
    Jun 2014
    i need help
    okuma osp 300 atc arm stand by on position
    help
    need ts parameters how opening:banana:
    Jun 2015
    4154
    Re: okuma osp 300 atc arm
    hi / if the arm stopped midway during change sequence, you need to reverse manually the sequence; there shoud be a black button on the panel, from where you should select atc and then reverse until current step = 0
    unfortunately, i can not share photos/printscreens at this moment
    also, what happened ? what caused the stop ? kindly
  1. Replies: 0
    Last Post: 01-07-2019, 04:49 AM
  2. Replies: 0
    Last Post: 04-21-2018, 06:23 AM
  3. Replies: 4
    Last Post: 10-05-2014, 04:14 PM
  4. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  5. Replies: 1
    Last Post: 08-28-2008, 02:09 PM
