584,837 active members*
5,384 visitors online*
    May 2019
    Unhappy Laser power loss with no loss on ameter.
    Hi Folks,
    I have an 80w Chinese laser that is about 20 days old. I have been using for about an hour a day since I got it. It has never been above 30%(10ma) power or above 15°C. I recently have been cutting 1/8" MDF at 10mm/s @ 30% power, it was cutting great.On the 4th day suddenly it would not cut at those settings and I noticed the power had dropped to 7ma when set at 30%. So I raised it to 35%and got it back to 10ma and it began cutting fine. On day 5 it would not cut again so I raised it to to 40% which got it back to 10ma and it began cutting again. Every day it has declined to the point that now I cannot cut 1/8 MDF at 65% power(17ma) even with 2 passes. The current levels have seem to stabilized but there still is no power to cut. Strangely enough @ 35% power I'm at 10ma. When I raise it to 45% it drops to 7ma. Then when I raise it to 55% it goes back up to 12ma. @ 65% it is at 19ma. I have cleaned all of the lenses with alcohol per the manufacturer. Any help that anyone can give would be greatly appreciated. I have a cheap K40 that cuts better.
    Nov 2010
    787
    Re: Laser power loss with no loss on ameter.
    Just buy new laser :-( Chinese junks are unpredictable.
    Best chinese lasers I had were BILL Laser. Even after 15 months in storage it was quite usable.
    CNC lasers, constructions, service
    Nov 2008
    644
    Does the beam look normal? Like not wandering. Not splitting. If it does it could be the power supply.
  1. 130w co2 laser LOSS OF POWER
    By cya_alex in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-26-2021, 09:38 PM
  2. Power loss, new 50W laser
    By roig12 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-18-2018, 09:51 AM
  3. Gradual power loss in Shenhui 690 laser
    By BrentFerguson in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-17-2016, 01:08 AM
  4. Laser power loss
    By Saurav in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-23-2010, 09:17 PM
  5. laser power loss
    By desibrown in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-26-2009, 11:43 AM
