hello pls check attached image
please, will someone create the program for it, and use a screen recorder ? i wish to see how others are doing this ...
or, at least an estimated duration, like, i don't know, xyz minutes ? also, what is the maximum time that you believe that is enough ( or you wish to be enough ), regardless of your programming skills ?
kindly
