586,011 active members*
4,388 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Rotary Phase Converter or New Drives ...Advice Needed
Results 1 to 2 of 2
    Feb 2010
    12
    I have a Tree Journeyman 320. I converted the electronics over to Dynamotion and ran it on 3 phase without a problem.
    I have two items that have taken place that bring me to a point where I'm a bit lost.
    1) My X axis started to violently shake if I brought a rapid motion to a stop too quickly. I didn't have time to sort it and identify if the problem was in the Getty N360 drive, the gould servo motor, or my less than professional tuning of Dynamotion.
    2) I lost access to 3 phase service when I needed to move the mill from work to my garage. So now I need to either convert the drives to something more modern or buy a rotary phase converter.
    I'm already driving the 2hp spindle with a VFD (220 single phase input). This only leaves a few things on 3 phase: a small lube pump, and the 3 axis drives.
    The system currently has three drives-
    Gettys N360 1/2 wave 240 VAC max, 3 phase 60 Hz; 12.5 A
    Gould permanent magnet servo Model: M113-A1.0K-900A;
    Back EMF Ke 34.2 V/KRPM; Current Lc Stall 12.5 amp.
    The motor doesn't list a torque.
    Based on the above information how do I calculate the power requirement of the 3 drives
    If I multiply by the square root of 3 (1.732) to convert from 3 phase to single phase ...1.732 x 12.5 amps = 21.65 amps per drive ...*3 drives = 64.95 amps using a phase converter on 220 single phase. and yes I will need to add the spindle at 6.2 amps * 1.732 = 10.7 ...for a total of 76amps on a 220 single phase circuit! IF I only drive the XYZ axis (not even the spindle) and I get 65 amps.
    Meanwhile, the Manual says connect the machine to 3 phase 220 and 30 amp line ...which means 51 amps on single phase. Both answers cannot be correct.
    Alternatively, how do I size replacement drives. for this machine? I may find myself doing this if the X axis cannot be cured by tuning. Any suggestions for drives and motors?
    Thanks,
    Gregg
    Dec 2013
    5717
    Re: Rotary Phase Converter or New Drives ...Advice Needed
    This might be worth a read through. https://www.cnczone.com/forums/servo...half-wave.html
    Jim Dawson
    Sandy, Oregon, USA
  1. Rotary 3-phase converter
    By chuck767 in forum Phase Converters
    Last Post: 03-01-2018, 06:55 AM
  2. 3-Phase Quality From Rotary Phase Converter
    By yoopertool in forum CNC Machine Related Electronics
    Last Post: 04-01-2015, 04:44 AM
  3. Rotary Phase Converter Questions - CNC grade RPC really needed?
    By cncmachine.ca in forum Phase Converters
    Last Post: 05-28-2011, 03:49 PM
  4. 760-22 with rotary phase converter?
    By tstom in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2008, 07:34 PM
  5. Help Needed Phase Balancing a Rotary Converter
    By Tayloned in forum DNC Problems and Solutions
    Last Post: 02-05-2008, 08:34 PM
