585,719 active members*
4,547 visitors online*
    Jun 2007
    99
    Easy method to cut "Fish Mouths"
    I have a lot of thin wall tubing (2.5" OD by .080" wall). I want to cut it in ~24" lengths, clamp it in two vises on a CNC milling center and cut a fish mouth in both ends. I plan to weld these to make a grid structure.
    I want to use common tooling. My thought was to put a disc near each end so the vise would not crush the tubing. Now I have the cutting issue. I am looking for a method that would cut the fish mouth fast and efficiently. Does anyone have some good ideas?
    Jun 2007
    99
    Re: Easy method to cut "Fish Mouths"
    I ended up using a 2" indexable mill and cut a "U", step down.. another "U"..etc.
    It only took about 5 minutes a side.
    Mar 2015
    409
    Make a clamp to hold the tube (2 steel plates, pressed together, turn/drill a hole, mill one side a fraction thinner), put it in a lathe, turn both pipe sides to the requested diameter and (identical) shape.!
  1. Glass manual "cutting" book of method , Requisite for on-site emergency
    By perfectmachinary in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-20-2018, 02:44 AM
  2. Brakeman Bob"So long and,Thanks for all the fish!"
    By SOLIDCAMSTEVE in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-25-2014, 08:06 AM
  3. "HVAC method of holding sheet metal"
    By CNCCajun in forum DIY CNC Router Table Machines
    Last Post: 12-08-2013, 03:05 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Fish "side view relief" profiles.
    By USMCCNC in forum Community Club House
    Last Post: 05-01-2011, 12:02 AM
