585,925 active members*
3,466 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > ramp option not able to unlselect
    Mar 2011
    357
    I have one tool path that is allowing me to select ramp or not
    Attachment 419780
    and one tool path that is forcing ramp on.
Name:	ruth ramp preselected.jpg
    I cant figure out what is forcing the ramping to be on.
    Can somebody point this out to me please?
    Nov 2014
    724
    Re: ramp option not able to unlselect
    Same request as before - upload the file, please.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Mar 2011
    357
    here you go
    Attached Files Attached Files
    Dec 2013
    5717
    Fusion assumes that you need to somehow ramp into a pocket, which is true. Therefore doesn't allow you to not use some kind of ramp in. It does allow the option of just plunging in, but some kind of ramp tool path is easier on the tools and machine.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2010
    171
    Yep... as Jim said: just select "plunge" if you are confident that your cutter can handle it in the material you are cutting (and the speed that you are plunging).
    (... and if you choose to, you can just create another sketch with "points" or circles where you want to make the plunge move, then select those points at the bottom of the 5th tab page as the predrill or entry point.)
    Example included:
  1. Replies: 0
    Last Post: 06-09-2016, 03:25 PM
  2. No ramp option when doing relief toolpath
    By tommy78 in forum Aspire
    Last Post: 11-30-2014, 09:39 AM
  3. Ramp?
    By tsaladyga in forum PTC Pro/Manufacture
    Last Post: 10-31-2013, 12:04 AM
  4. Ramp/Ramp out Contour help
    By ANorwood in forum Mastercam
    Last Post: 12-22-2012, 08:57 AM
  5. How can I ramp off....
    By gogego in forum Mastercam
    Last Post: 10-13-2011, 08:37 AM
