584,800 active members*
4,602 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > fusion file to big for control
Results 1 to 2 of 2
    May 2014
    4
    Hi just wondered what people are doing to run large filed on Fanuc 21IM Thanks Steve
    Jun 2008
    1838
    Re: fusion file to big for control
    How big is the file??
    Do you not have the PCMIA card for extra memory that was an option with the 12i M control.
    If not then "Drip Feed" is the best option, I always had this issue with my old Fanuc 0M and 0T machines and I just used cheap PCs to drip feed to them, there are some quite good units available these days that will hold large files on a USB stick that will drip feed to the machine, here is a link to one that is quite good from what I have heard, https://www.shopfloorautomations.com...le-usb-to-cnc/ saves having to have a PC at the machine but not as cheap as an old cheap PC or laptop although the DNC software is built in, good drip feed software that will feed multiple machines available here https://www.easydnc.com/
    Regards
    Rob
  1. How do I convert JPEG drawing to IGS file for fusion 360?
    By RussMachine in forum Autodesk CAM
    Last Post: 05-21-2016, 09:27 AM
  2. Expoting a DXF file from 2020 Fusion to import and use in Biesseworks
    By Rooster82 in forum Uncategorised CAM Discussion
    Last Post: 11-12-2013, 05:52 PM
  3. Fusion 640 Saving #variables to prog file
    By billygreen in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-26-2011, 02:56 PM
  4. Fusion control locking up
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-14-2009, 02:44 PM
  5. EIA file transfer to Mazak Fusion
    By grunemh in forum DNC Problems and Solutions
    Last Post: 02-23-2006, 06:28 PM
