585,722 active members*
4,144 visitors online*
    May 2008
    84
    Sinker Broken bolt
    When using a sinker edm to remove a broken bolt/drill etc.. How can you tell when you have gotten past the bottom of the broken Bolt, tap or drill bit? Does the voltage/amperage change? Or are there any indications?
    May 2019
    Re: Sinker Broken bolt
    Quote Originally Posted by claya View Post
    If it is a thru hole, you should see a change in voltage and flushing. If you have a blind hole, I would still watch for a change in voltage and flushing but you will have to pay closer attention to your depth and kinda just peck away at it.
  1. binding barrel bolt meets a carriage bolt
    By JEK5019 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-15-2019, 03:36 PM
  2. Broken Tap in 2nd of 8 hole Bolt pattern
    By Kennebec in forum SIEMENS -> GENERAL
    Last Post: 02-27-2012, 11:00 PM
  3. DIE SINKER???
    By Haasmanvf3 in forum Diemaking / Diecutting
    Last Post: 08-06-2008, 11:31 AM
  4. Seized and broken bolt removal
    By Caprirs in forum MetalWork Discussion
    Last Post: 12-08-2006, 05:26 AM
  5. Need some advice / help on broken off bolt.
    By Ace12GA in forum Mini Lathe
    Last Post: 09-08-2006, 10:44 PM
