584,879 active members*
5,427 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Jun 2015
    4131
    Re: National para
    I can't handle him, I can only smile wryly
    :argue:
    I am not sure, but is it dangerous to do so. Further I did not find G, M CODE MACRO in the parameter. Maybe we didn't buy it
    is not dangerous, but is also not common
    i am not using macros, thus i don't assign a custom G / M code to any soubroutine ... also, osp allows using soubroutines names up to 16chars, and this increases code legibility beyond using macros
    i am not saying that you should not use macros ....
    I tried installing but something related to API does not exist. Makes the device unable to Open the application after installation.
    you need to install api library; once installed, you should see an icon like in attached image; even so, i don't guarantee that those applications are doing what you need, or that they are not able to be ' modified / altered ' so to be ruined
    try the edit lock key ... is on the panel / kindly
  2. #22
    Apr 2009
    1262
    Re: National para
    G and M code macros are standard on all Machines since the E100. It may be set to not display. Go to parameters and then display then menu change. Make sure they are checked to display.
    The you can use either m or g code to call the subroutine of your choice. OSUB1.SUB for example.
    Experience is what you get just after you needed it.
  3. #23
    Jun 2015
    4131
    Re: National para
    hy duongcave, i just tried the edit key : it disables the ' quick edit - soft button ' and the ' program operation - hard button ' ... but you can edit the program in windows editor, and re-select it
    all those protection methods discussed were ok on a controller that is not os interfaced; i have some ideas, but they involve ' things ', like restricting MD1 on each cnc device, and using an external terminal for file management, with full control over MD1 ... but it sucks, when it comes to a simple program edit, like changing a coordinate
    however duongcave, there is a faulty perspective about how that machine + that operator is being checked ... in my opinion, there are methods to avoid all this mess and also to keep the operator, but ... just saying / kindly
    hy mr wizard, arround here, not all machines have this ; ' defaults ' may vary with area, with okuma dealer preferences, etc / kindly
  4. #24
    Jul 2013
    21
    Re: National para
    deadlykitten and OkumaWiz, thank you so much. I will study more about this issue.
  5. #25
    Jun 2015
    4131
    Re: National para
    by the way, why did you called this thread " national para " ? i mean, is it something patriotic ? nation stuff involved ?
  6. #26
    Jun 2015
    4131
    Re: National para
    hy duoungcave this is fresh : don't display msbs, and/or use a background process to spam the file inside md1 (or one way sync the md1), until the program is selected and executed, then alterate the min file; editing will require skills
    there is software capable of auto-loading the program, but, so far, i don't have experience with those / kindly
  7. #27
    Jun 2015
    4131
    Re: National para
    hi, check also this okuma app : https://www.myokuma.com/view-control
    kindly
Page 2 of 2 12
  1. Replies: 14
    Last Post: 07-23-2015, 06:53 PM
  2. Replies: 1
    Last Post: 11-13-2014, 11:05 AM
  3. Replies: 4
    Last Post: 09-08-2013, 03:01 PM
  4. posprocesador para num 1060 para alphacam como hacerme de el
    By chamitdi in forum Uncategorised CAM Discussion
    Last Post: 05-15-2013, 02:38 PM
  5. Replies: 1
    Last Post: 08-21-2012, 09:48 PM
