585,886 active members*
5,182 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CONFUSED... Where to home too... Help! where should my home switches be.
Page 1 of 2 12
Results 1 to 20 of 40
    Aug 2016
    185
    Very Confused about where to mount my home switches...
    I put my Z at the top of the column so I would assume it would home in the + direction.
    I put my X at the left side of the table which would home in the + direction
    I put my Y in the front (closest to me) and it home in the - direction.
    What I would like to know is the left front corner the place to home? and if that is so the when homed the X can only go in the negative direction and the Y only in positive right?
    1222
    Re: CONFUSED... Where to home too... Help! where should my home switches be.
    Is there some reason why you can't locate the home position as you describe?It appears to be logical and the positive direction of travel for X would be to the right and for Y it would move front to back.Having z homed at the top is also logical and you should generate a homing sequence that has it as the first axis to home.When machining you can locate the part datum and orientation to suit I would imagine.
    1943
    The home position really doesn't matter. It is only a reference position only. You can put the home switches wherever you want or where is most convenient.
    Aug 2016
    185
    Quote Originally Posted by routalot View Post
    I guess that was my question...Does it matter?
    Since I am new to this just wondered? I assume you would home the machine then mount your work and locate the work coordinates to somewhere in the middle of the X and Y travel right?
    Correct me if I am wrong but when the X axis MOVES to the right it is a positive direction correct... and Y is postive going away from you toward the column correct?
    Thanks!!
    Dec 2013
    5717
    Quote Originally Posted by truckeic View Post
    Thanks!!
    Here is the normal layout for mill axes, home position can be anywhere that you want it.
    Unless your home switches are very accurate, it is better just to zero off of the part that you are working on. There is really no need for a home position unless you have a tool changer. I don't have home switches on my mill, but I do have the ability to set a floating ''parking position'' to move the Z and table to a convenient location for tool and part changes that is invoked on a tool change command or program end. This is set per the job on the table.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    If that is where it works best for you then that is where you want them to be, Home switches double as limit switches also and is what soft limits are associated with so are an essential part of any CNC machine operation
    Mactec54
    1943
    While it is true that you can get by without home switches, they are very useful for not having to zero every time you turn on the machine. For example, 90% of my work is referenced to the fixed jaw of my vise, which is keyed to the table. I never have to zero the Y axis on power-up because I can just home the machine and it is set to within 0.0005" as the jaw offset is retained. Likewise if I am working on a part and don't finish it, I can just power down the machine, and when I power-up the next time simply home and the zeros are all set and ready to go. Without home switches you are required to re-zero every time you power up or reset the controller.
    Dec 2013
    5717
    Quote Originally Posted by 109jb View Post
    You turn your machine off? I just move mine to 0,0 and hit the E-stop.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    1516
    I home mine to the table centre and top of the column.
    I don't use limit/home switches just the software limits.
    Couldn't be bothered to fit any as soft limits works for me, can be a pain though to get machine co-ordinate 0.0 back exactly if it does go out.
    At days end with Mach3 I send machine home G28 and turn off. Next day I turn on and just hit ref all home button and good to go. It's stayed in position.
    It would be easier to go to a corner but my Y axis overhangs the base and I don't like to leave it in that position for any length of time.
    In my view having a machine home position is important because when G-codes start G28 G91 Z0 it will send the machine home first. If home is incorrect it can cause damage if you have no physical limits unless you change the G28 lines.
    Dec 2005
    436
    There are two main purposes of limit switches.
    1- In the case of any sort of malfunction the limit switch at the end of a travel will be triggered before one part of the machine crashes into another part of the machine. For example, If you are using Mach3 and disable Soft Limits and jog the X or Y axis till it reaches the end of the travel and the motor starts stalling makes noises...this is bad...don't do it, avoid it! Well if you had a physical electrical switch at the end of the travel, it would be tripped/triggered and stop the travel even if there were instructions to keep going, Its a safety mechanism.
    2- limit switches allow the machine to get a rough idea of where it is. If you program your machine to know a switch is at 30 and you trigger the switch, well you just told the machine it is in fact at 30 and not -5. This is a referencing function. But it may not be as precise as you need to machine. So the limit switches may give you a position +/- .5 accuracy, but your machining operation may need +/-.01. So it will be good enough to avoid crashing and maybe rough machining but if you have a jig, you may have to reference off the jig also!
    To be honest I don't have limit switches, Soft Limits in Mach3 are good enough for me.
    1943
    Don't confuse homing and limit switches. The OP asked specifically about homing switches and where to home. Home switches can serve double duty as limits, but can also be totally separate and independent switches.
    A good homing switch will have good accuracy. I use proximity switches for homing and have tested them to be accurate to within 0.005" (0.01 mm). I have also tested mechanical switches and the ones I tested were only a little worse (0.001" or 0.02mm) accurate. A lot is dependent on the homing sequence and what the homing speeds are set to.
    Saying a switch can only be used for the machine to "get a rough idea of where it is" may be true for a crappy switch, but is totally false if using a switch that provides good repeatability.
    Aug 2016
    185
    Thanks for all the great info and replies. This forum is indeed great..
    Sent from my XT1635-01 using Tapatalk
    Aug 2016
    185
    So just to help out this newbie...
    Homing a machine is really on necessary if you are using offsets and fixtures correct? there is no other reason to do it?
    Dec 2013
    5717
    About half the members here are going to disagree with this so I'll put my flame suit on, but...........
    For the purposes of this discussion I define required homing accuracy as +/- 0.0005 inch or better. This only applies to mills and lathes, there is some logic to using homing limits on a router because extreme accuracy is not normally required.
    The only reason to home a mill is if you have a tool changer and need to move the head and/or table to a specific location to effect a tool change. Other than that, the zero should be set to the work or fixture on the table and everything should be relative to that 0,0,0 position.
    Limit switches are almost required for overtravel protection, but are normally not accurate enough for absolutely locating the machine coordinates. There are limit switches available that do provide micron repeatability, but normally only found on higher end machines because they are expensive. A proper homing routine uses the index pulse on the servo encoder for final positioning. If your machine does not use servos, the homing can not be accurate.
    My knee mill does not have any homing provision, not needed. My Haas does home, it has a tool changer. My lathe also homes. Both the Haas and the lathe use the servo index pulses for final home positioning.
    Jim Dawson
    Sandy, Oregon, USA
    1943
    The above statement is just flat out wrong. There are many reasons to have a home position and you don't have to have switches to have a "home" position either . A home position can simply be located by witness marks so that you can get back to about that same spot within a reasonable accuracy.
    - Many controllers have software limits that allow definition of the work envelope to prevent reaching the end of travel. If properly set up and barring a failure the controller won't even allow the machine to be moved to its hard limit. Depending on the machine I would consider this a safety feature since some machines have axis drives that can break stuff. If you don't have any switches, depending on the controller you may be able to still use software limits, but to use soft limits you have to have a home position.
    - Not using a home position means that machine coordinates are essentially useless. Things like G28 and G30 locations are based on machine coodinate systems. G28 and G30 are commonly used by CAM programs for manual (not automatic) tool changes, but the definition requires using a home position.
    - G53 moves (Move in machine coordinates) would be arbitrary if you don't use a home position
    Everything? Yep if you only use the part zero everything will be relative to part zero. Lets say moving the Z all the way up is 10 inches above one part, but the next part is 2" shorter. Now Z all the way up is 12 inches above the part because you are referencing the machine from the part. On a machine using a home position, Z all the way up is just G53Z0. Nothing to remember or change. Same goes for X and Y coordinates. Now if I'm changing tools manually I want my machine at the clearest part of my table which is always at the same machine coordinates, but pretty much always at different coordinates relative to the part. To use the machine reference, you have to have a home position.
    Totally wrong. Homing can be as accurate as the switches and what is an appropriate level of homing accuracy is something each person has to decide. Just because you want sub-micron accuracy doesn't mean the next person needs it. Homing for use of things like G28, soft limits, etc, doesn't even have to be all that accurate. +/- 0.05" accuracy would be just fine for this kind of stuff.
    Granted the most accurate homing will be using an index pulse on the rotary encoder on the stepper/servo, but saying without this that "homing can not be accurate" is just BS. I have inductive proximity switches that I have tested the repeatability to less than 0.0005" (micron repeatability) and they cost me $30 for a pack of 10. Now if I'm making parts that have a +/- 0.005" tolerance, then explain why homing within 0.0005" is not acceptable. I would bet on 0.0005" homing accuracy on my machine but it is probably a little better than that.
    Aug 2016
    185
    Still learning here but I don't understand all the G28 and G30. If you feel like explaining them would love to learn. I am using Soft limits s I guess what you are saying is homing the machine everttime will make sure these soft limits are still "true". That does make sense.
    I have just installed simple switches on the mill I am not sure how accurate the mill is as it is a Harbor Freight mill with 1605 C7 Ballscrews added.
    Thanks all for the info!
    1943
    G28 and G30 are used as "predefined position". Invoking them moves the machine to the location that you the user has set for them. For example, on my Machine invoking G28 sends the machine to my tool change position which is Z all the way up,Table full left and back toward the column. So putting a G28 command always moves the machine to that same spot. That position is remembered by the controller even after a re-boot, BUT it requires using a home position. As said before that home position can be set manually, or you can home to switches. To set a position, all you have to do is jog to where you want it to be and send the G28.1 (or G30.1) command and where the machine is when that command is sent is stored as the location to go to when you invoke a G28 command.
    G53 is a coordinate system just like G54-G59 except that G53 is non-modal meaning that every time you want to move using the G53 coordinate system you have to put a g53 on the line. G54 for example is modal, so a G54 is remembered until changed by another coordinate system. The G53 coordinate system is considered to be the non-changing machine coodinate system. The G54-g59 are work coordinates and they change from job to job but G53 remains the same.
    15362
    A G53 can't be used if you don't use or have a homing system as it relies on the machine coordinates to move to
    G53 temporarily cancels work offset when used
    G53 is an Absolute move
    G28 is an Incremental move
    So both are quite different how the move also
    Mactec54
    15362
    And you don't want to even go there when you are learning or may be never G30 is unneeded for normal work you would most likely be doing so take that out of the equation
    So G28 used to be used a lot, not so much today as most machine can use G53 G0 and G53 is used a lot more, G0 Z0. will send the Z axes to the Zero position G53 will do the same thing but for it to be formatted correctly it is normally used with
    G53G0 or G53G1F200. G1 you need a feed move a G0 will move at the machine set rapid speed
    When used like this you can place it any where you want
    G0Z2.0.
    G53X--- Y---
    or it can be used
    G53G0Z0.
    G53X----Y----
    Mactec54
    15362
    Mactec54
Page 1 of 2 12
  1. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  2. Home switches and Limit Switches
    By TheBulk in forum DIY CNC Router Table Machines
    Last Post: 03-12-2011, 12:08 PM
  3. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  4. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
  5. Home switches and limit switches.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 04-08-2004, 11:32 PM
