585,758 active members*
4,323 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Need help mach 3 and g540 Chinese VFD xyz will not move
    Apr 2019
    IIm new to this bought the machine 2nd hand its a e axis running a Chinese vfd and a Gecko g540 When I first powered it up I could get evdrything to moce by running the g code simulator road runner patern after I programed the vfd everything was working I had to reinstal my OS ( window 7) now nonaxis movement I can cintrol the spindal
    Apr 2019
    [QUOTE=WEBB;2291706]IIm new to this bought the machine 2nd hand its a e axis running a Chinese vfd and a Gecko g540 When I first powered it up I could get evdrything to moce by running the g code simulator road runner patern after I programed the vfd everything was working I had to reinstal my OS ( window 7) now nonaxis movement I can cintrol the spindle from mach 3 but no axis movement Ive tried to reconfig the mach 3 but no success Im new to this so can anyone send me screen shots of their similar set up configuration Im well psst frustrated and think Im just digging a deeper hole I JUST WANT TO BUILD STUFF AND ITS MAKING ME CRAZY . Any input is greatly appreciated if someone has a configuration that may help Im at bodizifus@ msn.com thank you in advance !!
    Jan 2007
    467
    Re: Need help mach 3 and g540 Chinese VFD xyz will not move
    WEBB,
    Are you using our XML file to setup Mach3? If so, can you take a screenshot of your PORTS AND PINS section of the CONFIG dropdown?
    Marcus Freimanis
    www.geckodrive.com
  1. Gecko G540 - can' tell get motors to move
    By Goemon in forum Gecko Drives
    Last Post: 04-07-2019, 05:49 PM
  2. Mach 3 + G540 + UC100 + WJ200 = Can't run spindle from Mach 3?
    By zer0fighter in forum Benchtop Machines
    Last Post: 09-08-2013, 10:54 PM
  3. g540 w/ Mach3, Can't get motors to move.
    By speeddemon974 in forum Gecko Drives
    Last Post: 10-27-2011, 02:18 PM
  4. Can't get steppers to move with G540
    By sp1nm0nkey in forum Mach Software (ArtSoft software)
    Last Post: 06-25-2009, 11:12 AM
