586,005 active members*
5,111 visitors online*
Results 1 to 8 of 8
    Mar 2008
    82
    Add Button to PP
    Anyone know how to add an extra coolant button to PP to allow you to choose an M7 coolant during manual moves or with conversational?
    Jul 2016
    140
    Re: Add Button to PP
    Alt-M should do it. Adding a button is a pain in the ass because you'll have to re-add it after every upgrade.
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    Mar 2008
    82
    Alt-M ? Is that documented somewhere?
    Jul 2016
    140
    Keyboard shortcut for M7. I dont know. It might be in the docs.
    Mar 2008
    82
    Then whats the keyboard shortcut for M8 and M9?
    Mar 2008
    82
    Here it is: Alt-M
    Toggle auxiliary solenoid on and off (requires SmartCool MultiCoolant Module, PN 37168)
    1Cancel manual override with Alt + C or any subsequent M-code command.
    But there is still no way to specify M7 in Conversational without re-editing the code. Should be able to select M7 or M8 in Conversational.
    Thats for the shortcut.
    Jul 2016
    140
    M8 and M9 are toggled via Alt-F.
    Jul 2016
    140
    "But there is still no way to specify M7 in Conversational without re-editing the code.". That's correct as far as I know. I guess I didnt look past your "manual move" comment. Sorry.
    If you are familiar with glade and python, you should be able to add the button. The glade file is in /python/images. The python file you'll want to look at first is probably /python/conversational.py
    But as I said, its a pain in the butt to maintain the code. I have to do it on my machine every update.
  1. Think I need a better placed RED Button
    By rdsi in forum Tormach PathPilot™
    Last Post: 02-05-2017, 08:29 PM
  2. v25: Hey...what's this button do?
    By moldmker in forum BobCad-Cam
    Last Post: 06-25-2012, 11:39 PM
  3. Set jog to 10% with button/key
    By EL34 in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-06-2012, 09:13 PM
  4. Need button
    By ozzie34231 in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2009, 03:35 PM
  5. EZ button?
    By ericmattessich in forum LinuxCNC (formerly EMC2)
    Last Post: 04-29-2008, 06:59 PM
