585,996 active members*
4,222 visitors online*
    Mar 2016
    94
    POWER SUPPLY CONNECTIONS
    hi Guys
    can some one please confirm, before I do anything daft
    that the connections on the new supply are in a different order to the old one
    ie the 5v on the old is terminal 6 and needs to be terminal 1 on the new one etc
    it looks pretty obvious but just wanted to check
    cheers
    Dave
    Nov 2008
    644
    Re: POWER SUPPLY CONNECTIONS
    The old one is very standard. The new one lacks the IN signal. It must be combined with TH and TL. So they are not similar and not simply reversed in my opinion.
    Quote Originally Posted by Dtcrafts View Post
    hi Guys
    cheers
    Dave
    It is better to double check with the supplier before anything wrong.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2012
    145
    Isn’t the “in” just to the right under the new supply sticker?
    Mar 2016
    94
    hi
    guys
    thanks for the replies
    the IN signal is indeed covered by the green terminal connector
    I think I was trying to just confirm that all we need to do is to change the connections around to suit the new configuration
    well thats what I did and it works great
    just a shame that these HV lines cant be repaired, thats all that was wrong with it
  1. Connections/Power Supply for Leadshine MX4660
    By pbb116 in forum Leadshine
    Last Post: 01-28-2019, 10:04 PM
  2. AWC708L; Connections to Laser Power Supply
    By keverett in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2018, 07:34 PM
  3. 50 Watt Power supply connections question
    By Devoreg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2016, 05:30 AM
  4. China laser power supply connections
    By Billn in forum Laser Hardware
    Last Post: 01-23-2016, 05:47 PM
  5. Chinese Power Supply connections
    By thudson in forum CNC Machine Related Electronics
    Last Post: 03-20-2010, 04:29 AM
