585,715 active members*
4,563 visitors online*
Results 1 to 5 of 5
    Oct 2016
    19
    help with torq cut 22
    hi months ago I bought a torq cut 22 and this week I connect it and when I give it to enable the drives they activate the contactors and they are deactivated and I get the axis drive fault alarm, which could be this problem
    Oct 2016
    19
    Re: help with torq cut 22
    15362
    Quote Originally Posted by christian7r View Post
    Check the wiring and Voltage is set correct the Drives are feed from 2 Transformers T1 and T2
    Mactec54
    Oct 2016
    19
    ok I will check all the voltages right now the two transformers are set to 230v
    Oct 2016
    19
    that's the voltages that he gave me when I measured them but the t2 does not have the cable 40 nor the 39 that are of the 24vdc
  1. Looking at a Torq Cut 22
    By hax0red in forum Bridgeport / Hardinge Mills
    Last Post: 05-12-2020, 03:17 PM
  2. TORQ-Cut-22
    By tpmx57 in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2017, 06:42 AM
  3. Torq cut 22
    By Dirtman in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2010, 12:53 AM
  4. Need help! Torq cut 22 TLO..
    By Freewheels in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2009, 06:00 AM
  5. DNC to TOrq Cut 22
    By Drexelracing in forum Bridgeport / Hardinge Mills
    Last Post: 01-16-2009, 11:51 PM
