585,967 active members*
4,328 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Issue with ribbed surface (C-axis milling)
    So I've encountered this problem, which neither I or the machine technician are able to explain.
    I operate a Mori Seiki MT2000-SZ (similar to the NTX2000) and during XY-milling with the upper turret we get four backlash lines. But when we C-axis mill the entire surface gets covered in lines, initially we only had this problem with the upper turret, but now we've encountered the same problem with the lower turret two (which only has X, Z and C).
    We've made this piece before (half a year ago or so and we didn't have this problem), now the machine might have taken a blow since then so it's fully possible that things aren't alligned properly.
    The finish cut is done with simple G1s, G2s and G3s so it's not like it's a patchwork of a bunch of small coordinates.
    (pictures for reference) - https://imgur.com/a/g0lAYRB
    Re: Issue with ribbed surface (C-axis milling)
    I forgot to mention that it's done in G112 (polar coordinate mode)
    Uppdate:
    At lower feeds the surface becomes smoother, but the lines are still visible under a microscope (and more importantly after they've been blasted)
    (pictures of workpiece at lower feeds) - https://imgur.com/a/gug3MLZ
  1. Ribbed or timing belt for rebuilt RF-30 spindle drive?
    By martin_05 in forum Benchtop Machines
    Last Post: 04-02-2015, 08:38 PM
  2. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  3. 3D Milling Z axis to high on + side of concave surface
    By Craigpat in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-21-2014, 08:34 PM
  4. optically 'ribbed' surface
    By Ithink in forum MetalWork Discussion
    Last Post: 04-22-2008, 08:59 PM
  5. Replies: 11
    Last Post: 10-13-2007, 07:03 AM
