584,862 active members*
5,722 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > How to wire VFD using Arduino/GRBL
    Mar 2011
    333
    I am at the point where I want to control my VFD/spindle with G-code and my arduino/GRBL/UGS set up.
    How do I do this?
    Mar 2011
    333
    Re: How to wire VFD using Arduino/GRBL
    anybody?
    Somebody must have done this?
    Aug 2009
    1567
    What VFD do you have? Make Model ....post the pdf Manual here for both arduino hardware and your VFD of what you have. Helps to have the roadmap of where to go
    Mar 2011
    333
    I am running an Arduino UNO(not a knock off)with a proto screw shield and GRBL 1.1. It is a 3kw Huanyang VFD.
    Attachment 420152
    I am not aware of any PDF of the manual but I have a hardcopy.
    Mar 2015
    409
    GRBL outputs a 0..5 Volt PWM signal. This has to be fed into your VFD. If your VFD doesn't accept PWM signals, you have to add a PWM to Voltage converter. There are modules to but like this one https://www.banggood.com/PWM-To-Volt...r_warehouse=CN but I don't know if it is any good.
    As an alternative, you can add a resistor/capacitor filter to change the PWM to a voltage signal. Beware, the output is than limited to 0..5 Volt, the arduino voltage swing.
    GRBL also has an output signal that can be used to just start (power on) the spindle. This signal can be fed to a relay that powers the spindle motor. But maybe your VFD has an input signal to do this that accepts 0..5 volt.
    You can do both, start the spindle and set the speed.
  1. Which pp to choose for arduino grbl?
    By CptanPanic in forum Post Processors
    Last Post: 03-08-2021, 11:05 PM
  2. GRBL 1.1 ARDUINO uno pinouts
    By tkms002 in forum Arduino
    Last Post: 04-29-2019, 03:06 PM
  3. Arduino GRBL VS LinuxCNC
    By valmar in forum DIY CNC Router Table Machines
    Last Post: 01-15-2018, 05:50 PM
  4. Arduino/Uno/Grbl
    By Mckyjns in forum Arduino
    Last Post: 08-22-2017, 03:14 AM
  5. arduino nano with grbl
    By mrsnowie in forum Hobby Discussion
    Last Post: 01-06-2016, 06:25 AM
