585,902 active members*
4,548 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > EAAK water jet cutting machine EK3020 for glass marble cutting
    Product description:
    Water jet cutting machine is kind of using high pressure water cutting machine, belong to the category of could cutting, has the avantage such as compact structure, no sparc and not produce thermal deformation or heat effect. A high pressure waterjet cutting machine is a tool used for slicing metal and other materials using a jet of water at high velocity and pressure. Featuring a low noise, no pollution, high precision and high reliability, our water jet cutting machine has been used in a variety of applications, including mining, automobile manufacturing, paper manufacturing, food, art and architecture. Water jet machines can be used to cut rubber, foam, plastic, composite, stone, tile, marble, glass and other materials.
    Features:
    • 50 HP High 420 MPa pressure for smooth finish cutting at high speed.
    • Main heart of Supercharger, "Intensifier" is "Made in USA".
    • User friendly & minimum maintenance cutting head design with USA make "Water Switch Seal Kit" & other parts.
    • All parts of machine are processed on Highly accurate YASKAWA servo motor (made in Japan). Which gives you trouble free operation & long life of parts.
    • Use special water cutting machine software, a day to achieve a comprehensive grasp
    •Non-standardized model design customization?Customizable submersible adjustable water level platform, equipment working noise is lower than 75Db.
    Contact:
    EAAK Water jet Cutting Machine
    [email protected]
    Nov 2019
    Best water jet marble tile ?
    How do I know which service is the best among the ones listed here?
    https://www.mosaic-tile.net/Home-dec...earl-tile.html
  1. water jet glass cutting machine-sinowaterjet
    By sinowaterjet in forum News Announcements
    Last Post: 12-20-2016, 04:25 AM
  2. Water jet cutting machine for cutting glass stone metal
    Last Post: 07-16-2014, 07:48 AM
  3. Special water jet glass cutting machine SN2030R
    By Sino-waterjet in forum News Announcements
    Last Post: 07-01-2014, 09:41 AM
  4. Water jet glass cutting ( water jet seller)
    By sizala in forum Waterjet General Topics
    Last Post: 03-17-2012, 12:59 PM
