585,996 active members*
3,850 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > Losing Z steps mach 3 on converted new hermes engraver
    Feb 2004
    84
    I converted a New Hermes 3400 engraver using the OEM drives and steppers with a cheap ebay breakout board, and am consistently losing steps in the Z axis only, where the cutter ends up higher than it should. Note that this machine is designed so a spring loaded foot contacts the workpiece (to provide a consistent engraving depth even on somewhat flexible material by pushing down on floppy plastics) and the Z stepper, an Oriental Motor Vexta PH268-21-c68 2 phase, 1.8 degree 5.4vdc 1.5A is the same motor as the other axes which work fine. I think I've used very conservative values for motor tuning, (steps per 2000, velocity 30, acceleration 2, step pulse 5, dir pulse 5, same as the other axes) as speed is not that important to me. I thought maybe because the z motor was sometimes working against the spring that that might be causing the issue but the motor has no problem overcoming that force at the beginning of jobs, the problem happens in the middle of a job. I'm not sure what the step pulse or direction pulse settings do, should I adjust those to something other than 5 and 5 or is there some other adjustment I should make?
    See my stuff for sale at http://stores.ebay.com/Industrial-Tool-and-Machine-Works?refid=store
    Apr 2004
    5737
    Re: Losing Z steps mach 3 on converted new hermes engraver
    According to this datasheet: https://datasheetspdf.com/pdf-file/9...xta/PH268-21/1 that motor has an inductance of 6 mH per phase, so it really wants about 78 volts of DC electricity supplied to run optimally. How much voltage are you giving it?
    Andrew Werby
    Website
    Feb 2004
    84
    Quote Originally Posted by awerby View Post
    It uses the OEM power supply and drives, so whatever the stock voltage was.
    Feb 2007
    19
    Quote Originally Posted by tom.jelly View Post
    Hi I am doing the same conversion , can you tell me how you went from the break out board to the oem driver. Any information would be greatly appreciated. Thank You
  1. New Hermes Engraver
    By aminear in forum Engraving Machines
    Last Post: 07-22-2022, 12:44 PM
  2. Converted X2 to CNC now trying to get my steps per adjusted... Help
    By truckeic in forum Mach Software (ArtSoft software)
    Last Post: 07-15-2017, 06:11 PM
  3. New Hermes Laser and Engraver
    By starlight in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-07-2011, 01:56 AM
  4. Losing steps with servos and Mach 3
    By tjs88yj in forum Mach Mill
    Last Post: 02-01-2010, 02:55 PM
  5. New Hermes nhi 810 engraver
    By hopeitworks in forum Engraving Machines
    Last Post: 08-15-2009, 11:02 PM
