504,214 active members
4,773 visitors online
Results 1 to 2 of 2
    Registered
    Sep 2012
    Bodor laser not initiating cuts
    We have a 4ft x 8ft Bodor-built laser we have been using in production for our light fixtures. We had some problems with the laser coming down, starting a path but not firing fully on the metal settings. It would run around and just sparkle or after a few inches fire full power but not cut cleanly. We contacted Bodor and got great tech support. They walked us through all sorts of settings. It took a bit of time to dial it all in and diagnose but they were committed and worked with us step by step.
    For anyone looking to short cut this process if you run into this problem, for us it was not a controller issue as we thought, but it ended up being a function of the auto-height follow settings and the pierce delay not being set correctly. We had to add a delay of up to 6mms after piercing before starting the cut. That was set in the MetalCut software. The next issue was resetting the auto height sensor height to 3mm so it was closer to the sheet. It was a weird problem to diagnose. We thought it was in the laser, or the two power supplies controlling it but it ended up being a settings issue.
    We never would have figured that out without their help.
    Member
    Aug 2009
    177
    Re: Bodor laser not initiating cuts
  1. Bodor Laser 25000w Super Power Laser Cutting Machine World Debut
    By Bodorlaser in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 04-09-2019, 07:41 AM
  2. Bodor USA Demo Laser
    By iGAK in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 07-26-2018, 07:06 PM
  3. CO2 Laser Bodor
    By julianjaimes1985 in forum Laser Hardware
    Last Post: 07-24-2018, 10:02 AM
  4. Novakon/Bodor Laser Projects
    By iGAK in forum Novakon-Lasers
    Last Post: 04-25-2017, 06:39 PM
  5. New Tube but only cuts for 30second then laser cuts out
    By JBxrayman in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 07-11-2016, 05:57 PM
